Thread: Aqua Logic Main Control Board Tripping Breaker
    Hi, I have an Aqua Logic Chlorine Control System (not sure of the model #) and it tripped the main 120V breaker the other day.
    1. Verified the two fuses on the main board are ok (20A, and 3A).
    2. I disconnected the two main 120V input wires to the main control board (black and white), turned on the breaker and it did not trip.
    3.I plugged the wires back in and the breaker tripped again.
    4. I measured the resistence across the 120VAC input terminals on the main board. It was ~35 Ohms.
    5. I measured the resistence across RZ1. It was also ~35 Ohms.
    6. Removed RZ1 from the board (de-soldered) and measured the resistence across the 120VAC terminals on the main board. Resistence was ~ 35 Ohms.
    I don't know what the values should be in the above measurements, but 35 Ohms between 120VAC input terminals doesn't seem right.
    Here is a link to a picture of the board (sorry, I don't know how to attach the image): http://www.amazon.com/Hayward-GLX-PCB-M ... B0030E95PO
    Does anyone have any information or ideas?
    Thank you.
    kellyetheredge's Avatar
    Mar 2013
    Lubbock, texas
    43
    Re: Aqua Logic Main Control Board Tripping Breaker
    Do you have a "Diode " test on your meter....?
    14,364gal AGP
    Intex Ultra Frame 16'x32'x52"
    Krystal Clear™ Sand Filter Pump & Saltwater System - 2,650 GPH**Nite-Brite Halogen Pool Light
    TF-100 Test Kit (This kit Rocks)
    Yes. I do have a diode test on my meter.
    Ok. I sent the board out to be repaired. I installed it, and the same thing happened. The 15A breaker tripped immediately. I unplug the black wire (120VAC) to the board and the breaker stays on.
    Please help....
    22,542
    Sounds like it may be a shorted transformer. Have you checked it for a short to ground?
    Is the breaker a GFCI?
