Thread: Chlorine off season prices?
    Here we are in the middle of August and im dangerously low on chlorine (shock and tabs). I know that buying in bulk is the most cost effective way to go, but I dont want to buy a huge amount right now considering the season is almost over. So two questions: Who has the best prices on granular chlorine in smaller quantities and 3" tabs in the same smaller quantities? Secondly, how cheap do the 50 pound buckets get during the fall and winter when nobody is buying them? I think the cheapest I have seen Leslies Power Powder Pro was $119 recently.
    Thanks in advance!
    17k IG vinyl
    1 HP w/sand filter
    built 1996
    Aug 2011
    Southern California
    188
    Re: Chlorine off season prices?
    No more Leslie tabs for me.
    I used them for almost 15 years and have now seen the light. Tired of buying more and more chemicals to offset the EXTREMELY high CYA build up.
    Now using liquid chlorine and no more problems.
    Thanks again to TFP. I'll be a supporter shortly, to help the website.
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Generally, your warehouse stores will have the best price, even better than the pool store off season prices.
    That being said....I don't think you'll need those items anyway. I'm following your other post and I don't think you want to get that situation again.
    Did you get your test kit yet? Let's get on over to that other post and get some real test results posted.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Quote Originally Posted by UN1017
    Point taken lol.
    17k IG vinyl
    1 HP w/sand filter
    built 1996
