Thread: In-Floor Cleaning System Repair
    Hello all,
    I've been having some recent problems with my in-floor cleaning system. I have a general understanding of how they work, but I'm no expert by any means. That said, I noticed that when my in-floor system turns on, all of them are up at the same time. It's a 6-valve system, so from what I understand, only some of the pop-ups should be up at any given time. There are two issues with all the popups being up at once: First, not enough pressure is going to each popup, making their cleaning power extend no more than a couple feet from the head. Second, because the stations are not revolving, the heads are not allowed to change direction.
    I have a feeling this has to do with the "gearbox" that feeds the six stations. I opened it up and noticed that it's over 5 years old and very worn out. I'd like to try and replace this part, but I have no idea where to look for the best deal. I called a pool company, and they wanted over $300 for the part! It's an integral part of the system, but I have a hard time believing a piece of plastic with a couple springs could cost that much...
    Do you guys have any recommendations on where to find this part for cheap? Also, if you have any other thoughts as what might be my problem, please feel free to share.
    Thanks in advance!
    In-ground pebble tech pool and spa. Cartridge filter pump. Chlorine sterilization. In-floor cleaning. Waterfall. Spa jets. Jandy pumps. Jandy Colors lights. Jandy control box with iLink PDA v3.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: In-Floor Cleaning System Repair
    Quote Originally Posted by Fill in the Blank
    Doesn't surprise me at all, though I'm quite certain the part doesn't cost them nearly that much.
    I'm sure you can get better pricing on the net. Here's a couple of places to get you started...
    http://www.infloorpoolparts.com/
    http://www.poolcenter.com/parts_infl...s_poolstor.htm
    http://www.poolcleaningparts.com/
    http://www.inyopools.com/pool_part_c...ner_Parts.aspx
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    What brand is your system? If you're not sure, post a picture and we'll take a look. $300 is almost certainly a ripoff.
