Results 1 to 8 of 8
Thread: Question about Taylor K2006
    I've read on this site that this kit can test chlorine up to 50 ppm...but looking at the pictures of the test cells it looks like they only have one more "window". I.e. chlorine looks like it only goes up to 6 and ph up to 8.4 ??
    What am I missing?
    I've been using a Taylor K 101 Basic kit and, if I understand correctly, it can only test chlorine up to 5 ppm...
    38,371
    Re: Question about Taylor K2006
    The FAS-DPD portion of the test kit does not use color matching blocks. You count drops until the color changes from pink to clear:
    extended-test-kit-directions-t25081.html#p206393
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    The kit can measure the FC using the color block up to 5FC or 50FC if you use the FAS-DPD portion of the kit. The TF-100 kit will do all of the tests you need and the bottles of reagent are a better value than the Taylor kit. Both the TF and Taylor kits use Taylor chemisty and chemicals/reagents.
    -- Guy --
    30,426
    For clarity, you have something mixed up. The K-2006 has no "test cells" (comparator block) for chlorine.
    The K-2006 ONLY tests chlorine using the FAS/DPD drops based test and it will test chlorine to 50+
    The TF-100 has both the comparator block (up to 5 ppm) chlorine test and the FAS/DPD chlorine test (50+ ppm).
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Could it be the K-2005 instead? There is a difference!
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Sorry. I looked online and the image I looked at showed both a block and the FAS
    http://www.poolsupplyworld.com/Taylor-K ... ign=K-2006
    -- Guy --
    Mar 2007
    San Rafael, CA USA
    12,082
    That's just one color block for pH and the other side is for CYA. No color block for chlorine in the K-2006 (also shown larger here). At first glance it does look similar to the dual color block of the K-2005 (also shown larger here), but it is different.
    Ok. Read the extended test kit directions.
    Thx
