Thread: Heating a spa
    Jun 2013
    Plymouth Meeting, PA
    29
    Heating a spa
    Hi there -
    Quick question. I have built in spa on the side of my pool. What is the most efficient way to heat just the water in the spa in terms of valve openings.
    Right now I have Suction set at 50% main drain, 50% skimmer. The Return is set to 50% Pool, 50% Spa.
    I dont want the spa heated all the time, just when i have parties on the weekend. Should i set the return to 100% spa with the heat on in that case?
    Thanks!
    25,000 gallons (in-ground plaster pool+spa)
    Hayward DE Filter, 1.5 hp pump, Polaris 3900 Sport Vacuum, Honeywell Heater
    TF-100 Test Kit, Using TroubleFree Method
    Getting the hang of pool ownership....
    22,542
    Re: Heating a spa
    To just heat the spa you want 100% suctions and returns to the spa and zero to the pool.
    38,242
    Re: Heating a spa
    What Dave said.
    Do you have another valve besides the one you mentioned on the suction side? That sounds like one to balance the floor and skimmer suction lines in the pool ... should be another valve.
    Add a picture of the plumbing setup if you are unclear.
