Results 1 to 11 of 11
Thread: Adding chemicals when the "returns" are in the pool floor
    Apr 2012
    Puglia, Italy
    133
    OK, I have seen lots of posts saying you shouldn't just add chemicals over the side, but in front of a return. My problem is that my returns are in the floor of the pool, with the exception of one return which is in the 80cm deep childrens pool. I don't really think it is a good idea to be pouring chemicals, particularly acid, in such shallow water. I can't see any other way than over the side. The way we do it now is slowly over the side, mostly at the deep end, and above the bottom drain, which is always open as we use it for filtering. Any other suggestions?
    Pool is an infinity pool, so "skimmers" are over the edge.
    Thanks for any advice you can give.
    400,000 Litre in ground infinity pool, with 40,000 litre holding tank (116 235.703 04 gallon). Vinyl liner.
    Two Astralpool Cantabric sand filters, 900mm diameter, each with 550kg of sand.
    Two ESI MP6 1.5kw 3 phase pumps.
    38,305
    Re: Adding chemicals when the "returns" are in the pool floo
    I would pour slowly in the deep end and then brush the bottom to ensure the chemicals mix.
    Apr 2012
    Puglia, Italy
    133
    Thanks.
    The deep end is 2.8 metres deep, so brushing is challenging to say the least. Our vacuum brushes at the same time, so it does get brushed at the same time as cleaning, but difficult to do every night. My husband does the actual pouring, and does pour slowly, and in several places around the deep end.
    I guess some of it gets sucked into the bottom drain, through the pumps, then out through the 8 returns in the floor, so it must be getting reasonably mixed.
    What dangers should we be mindful of when doing this - I mean damage to equipment, liner etc., as well as danger of splashing ourselves.
    38,305
    If the chemicals end up sitting on the liner than you could fade the liner.
    Apr 2012
    Puglia, Italy
    133
    OK, will bear that in mind. Will just have to pour ultra slowly in several places to try to avoid that happening.
    Jun 2011
    Long Beach, CA
    2,790
    You might try mixing the chemical with pool water in a 5 gallon bucket of water, then pouring it in slowly. After the bucket is empty, fill it up with pool water a couple of times and dump it into the pool which cleans the bucket and mixes the chems throughout the pool some more.
    Apr 2012
    Puglia, Italy
    133
    Quote Originally Posted by ping
    Can give that a try, but there are times when we are putting 25L of chlorine in at one go. This is a big pool. See my signature for the volume of water we are talking about.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    IMHO you really need to look at injection pumps...stenner or similar. It would add the LC via the return line by using a timed pumping of LC. Much less handling risk and you could use larger containers... 15g-55 gallon barrels.
    -- Guy --
    Apr 2012
    Puglia, Italy
    133
    Quote Originally Posted by techguy
    Sounds like a good idea. Will have to see what is available here in Italy.
    We have thought about getting bulk liquid chlorine delivered to save all the humping, and a couple of friends have changed to BBB recently, so we could share the cost with them. Then maybe we could put some sort of injection pump between the large container and the returns.
    Will talk to our plumber type guy next week. This week is the main Italian holidays, so nothing happens this week.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    What does the infinity edge flow into? Could you add there? Got pictures sounds neat?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    DigbyAllen's Avatar
    Westchester, NY
    113
    That sounds like a heck of a pool. I'd love to see a picture.
    Jim
    Intex 15' x 42" -- 4,000 gallons
    installed August 2012
    Intex 2650 sand filter, Hayward skimmer
    TF-100 test kit, TFP method
