Results 1 to 7 of 7
Thread: Rain and cya levels
    Jun 2013
    Northern NJ
    123
    Rain and cya levels
    We have had a lot of rain lately so I had to dump some water Before that, my cya levels were 140. , now they are down to 100. Will a little dumping reduce the cya that much. I was planning on draining about 40% at end of season now I'm not so sure I will need to. Any thoughts?
    36,000 gal IG vinyl. Haywood pump and heater Hayward DE filter blue diamond robot. Hayward Aqua Rite SWG AQR-15
    22,553
    Re: Rain and cya levels
    It's strickly a percentage. If you replace 25% of your water with CYA free water (i.e. rain) then your CYA will go down by 25%. Another problem is that above 100 ppm the CYA tests aren't accurate at all.
    How did you test the CYA?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Thesil
    It certainly could depending on Rain Level and dumping amounts. You are still too high at 100 however. If you have a SWG you can just take it down to the 60-80 range. If you don't, I would suggest taking it down to the 30-50 range.
    Essential Links:
    Jun 2013
    Northern NJ
    123
    I tested with the Taylor kit
    22,553
    Did you use the dilution method to get the 140 ppm number?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,067
    It's much easier to test the pool with lower CYA - your minimum FC level will be in the range where the color matching test works. Otherwise it's FAS-DPD every time. Grab as much of that rain as you can! Also note that whatever % CYA goes down, salt will go down as much, so you'll need to replenish it.
    Jun 2013
    Northern NJ
    123
    Yes I used the dilution method to get the 140 number
