Results 1 to 9 of 9
Thread: chlorine
    May 2013
    Cyprus
    159
    chlorine
    What is the best way to introduce chlorine to the pool. with or without the pump running, around the sides or directly over the return.
    Living in Cyprus
    Still enjoying life
    22,549
    Re: chlorine
    If you do much reading of the posts here you'll see that without exception, it's recommended that it be added in front of a running return.
    May 2013
    Cyprus
    159
    Re: chlorine
    Thanks
    I know that these questions have been asked before but it is how to find them as I am not used to navigating this system
    Living in Cyprus
    Still enjoying life
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: chlorine
    You can use the Google search box in the upper right corner.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: chlorine
    I would just add the word, slowly to Bama's reply
    38,285
    Re: chlorine
    And let the pump run for about an hour AFTER adding any chemicals ... a quick brushing can also help ensure the chemicals mix and do not sit on the bottom.
    Re: chlorine
    I start off really slow until I see the stream moving the chlorine away, then speed it up just a little. I dose at night and leave the pump on until morning.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    May 2013
    Cyprus
    159
    Re: chlorine
    Thanks for your help I know it can be frustrating to you experts when the same questions are asked time and time again, but I was unaware of the search box and anyway personal contact is always better makes me feel human.
    Living in Cyprus
    Still enjoying life
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: chlorine
    I normally say to pour it a stream less than the diameter of a pencil in front of a running return. Letting the pump run for at least an hour is a good plan. If you need to add chlorine and then measure your FC, like in a SLAM, this would be a good process.
    -- Guy --
