Thread: Heat Pumps
    Heat Pumps
    Can a Heat Pump heat both a pool and a spa. Better yet, can it effectively get a spa hot ?
    Thanks
    Ft Lauderdale, Florida
    1,455
    Re: Heat Pumps
    Assume that a large heat pump puts out about 1/3 the BTUs of a large gas heater, it means that it will take about 3 times longer to get the spa heated up to your desired temperature. Instead of 15 minutes, it will take 45 minutes, but you can get use to starting the heat pump up earlier for the great cost savings benefits real easily.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
