Thread: high cya
    May 2013
    Cyprus
    159
    high cya
    my cya is high and I need to replace a lot of water to bring it down. I replenish lost water at about halt a ton a day, will doing this also lower my cya though I assume a lot slower process.
    Living in Cyprus
    Still enjoying life
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: high cya
    Anytime you replace high CYA water with fresh water, you are lowering the CYA.
    -- Guy --
    May 2013
    Cyprus
    159
    Re: high cya
    Thanks
    Nice to have conformation, appreciate your input.
    Living in Cyprus
    Still enjoying life
    Jun 2012
    Howell, NJ
    977
    Re: high cya
    Well, if the water you replace is lost to evaporation, that won't lower the CYA. Only if the water is drained or lost to splash out will it lower CYA.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    May 2013
    Cyprus
    159
    Re: high cya
    Thank
    I never thought of that.
    That means if the water level is low the cya will increase. And the when the pool is filled the cya decreases.
    But the cya does not evaporate.
    Got it.
    Living in Cyprus
    Still enjoying life
