Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Ton of rain today + debris
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    We've had a lot of rain this month and my fc and cc levels have been good. Since my cpsc48 went out, I'm back to bleach, and a bottle of 8.25% a day keeps it between 3 and 7 with a cya of 70.
    Today's rain was heavy, pool is to the rim, and a ton of dead grass clippings got into the pool and turned it cloudy. I can see the bottom of the shallow end, but not the deep end.
    I came home to find it and put in 2 6% 121oz bottles and a little bit of 8.25% which brought my level from 3 to 10.5ppm
    2 hours later it came down to 9.5 and cc levels are still 0.5 or less.
    Went bottle shopping after depleting my stash, calculated I needed 3.5 bottles to bring it up to 20ppm shock level. I put in 4 bottles and measured 22ppm after an hour and will retest in the morning.
    [attachment=2:uqdcbx5k]ImageUploadedByTapatalk1376455711.815954.jpg[/attachment:uqdcbx5k]
    [attachment=1:uqdcbx5k]ImageUploadedByTapatalk1376455724.614347.jpg[/attachment:uqdcbx5k]
    [attachment=0:uqdcbx5k]ImageUploadedByTapatalk1376455737.233444.jpg[/attachment:uqdcbx5k]
    27000 gal 18x36 rectangle In-Ground built in 1978
    Vinyl liner, 3/4hp Hayward Super pump, single speed 3450rpm
    SWG: Hayward Aquarite AQR15
    Sand Filter: 300 pound sta-rite T-240BP-1, 3.14 sqft surface area
    K-2006 Test kit
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: Ton of rain today + debris
    Sounds like you need to keep your FC high until the debris is filtered out and the algae is killed (and filtered). We call this process the SLAM process. Read Pool school, link in top corner of page.
    When you are SLAMing the pool, it's all about keeping your FC in the shock range for your given CYA.
    -- Guy --
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    I hate to be the bearer of bad news, but the bright side is, there's a silver lining to this cloud.
    Unfortunately you became susceptible to, and ultimately the victim of algae growth as a result of maintaining too low an FC for your CYA.
    The minimum FC for bleach/LCL as a CL source at a CYA of 70ppm is 5ppm FC, not 3.
    At that low an FC, there simply wasn't enough chlorine to keep the organics at bay to prevent algae growth.
    I presume the mix up happened when you switched from your SWCG as the pool's CL source to bleach/LCL. SWCGs produce pure HOCl, the active sanitizing agent in bleach/LCL. It's stronger and more potent in sanitizing power per ppm than bleach/LCL. So at the recommended CYA levels for SWCG chlorinated pools, you run at a lower ppm FC.
    Which just so happens to be 3ppm, what you were dosing to with bleach/LCL.
    So I can see where the mixup so easily happened. It can be confusing, but live and learn, right?
    Now you'll be armed for the future though.
    See this url for future reference and affirmation of the differences in CL source.
    pool-school/chlorine_cya_chart_shock
    Also, having caught it so early, you've got a major leg up on it!
    As it doesn't look that bad, usually about how a green swamp looks mere days before the finish line, a week or more into SLAMing. I wouldn't be surprised if your SLAM operation goes preeeetty quickly!
    I'd say that's pretty cool news as well.
    Hang in there, show that mean ol' algae who's da' boss!!
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Thanks, Yes for some reason I didn't pick up any difference on pool calculator. I just checked and low n behold it saying 5-10, so bad on my part.
    Fc fell from 22 to 18 overnight, cc is still less than 0.5.
    I put a 121 oz jug of 8.25% in this morning since I won't be home till this evening.
    K-2006 Test kit
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by x2rider
    Yep...this is evidence that you need to SLAM. Failing any one of the SLAM testing criteria is enough evidence to SLAM.
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Yes, Slam Test criteria status:
    A: Pass
    B: Fail
    C: Fail
    Controls set to full speed ahead, maintaining shock level!
    K-2006 Test kit
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Ok Pool Calculator says shock level should be 20 for 70 CYA, but the chart says 28, which is right?
    K-2006 Test kit
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Go with the 28Fc, it's better for SLAMing
    -- Guy --
    Smykowski's Avatar
    Sep 2011
    3,065
    Both work, but the chart values are more aggressive than PoolCalc. If you use the higher number, the process will go faster.
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Thanks, I saved a local copy of the pool calculator page, updated the estimated shock level calculations to match the chart, and to add 121oz, 8.25% bleach for my reference.
    K-2006 Test kit
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    Quote Originally Posted by y_not
    ... SWCGs produce pure HOCl, the active sanitizing agent in bleach/LCL. It's stronger and more potent in sanitizing power per ppm than bleach/LCL. So at the recommended CYA levels for SWCG chlorinated pools, you run at a lower ppm FC....
    You are saying that 3ppm (or 10, pick any number) free chlorine from bleach, as measured by our TF-100 kits, has a different effect than 3ppm of free chlorine made by a saltwater chlorine generator. I don't understand how that's possible.
    Would that mean that the algae killing power of 10ppm FC from cal hypo is different from the algae killing power of 10ppm FC from trichlor or bleach?
    I'm a little confused.
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    May 2013
    Fort Lauderdale, FL
    423
    With the pool level that high, isn't that negating the effect of your skimmer? Mine won't pull surface debris if the water level is too high. I would backflush or pump to waste to get to where the skimmer works again.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Oh ya, it's almost 3" above the top opening, In fact I added 1200 gallons to the pool calculator to compensate. I plan on doing a good vacuuming-to-waste tonight, so I'll use that up no problem.
    K-2006 Test kit
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Had my wife put 2 121oz bottles of 8.25% in at noon, came home and it measured 18. My son vacuumed and backwashed for me this evening, and about 10pm it was at 16. put in 4 bottles to raise it to 28. CC almost zero, barely any pink tint at all with 5 drops in 10ml sample.
    With my high powered Brinkman LED spotlight, I can just start to see the bottom of the deep end already. It's no longer a greenish tint, but more of a white cloud.
    Progress!
    K-2006 Test kit
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    White cloud will oOn become blue white and progress towards blue and clear. Keep going! Keep brushing, keep filtering.
    -- Guy --
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Last night only fell from 28 to 22
    Too dark when I left this morning to take pics, and it was only like 60 degrees outside this morning, crazy cool for us this time of year. Might be spending more time in the hot tub soon.
    K-2006 Test kit
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    Wifey sent me this, not sure if you can see it online, but I zoomed in on it on my phone and I think I am able to see the bottom... Or it's clouds...
    [attachment=0:1dq4c9yj]ImageUploadedByTapatalk1376587751.038573.jpg[/attachment:1dq4c9yj]
    K-2006 Test kit
    38,305
    Quote Originally Posted by CUTiger78
    No ... a ppm is a ppm.
    The SWG can be run at lower FC levels due to a few reasons, the biggest is the harsh environment within the cell.
    Here is a better answer from Chem Geek. I think y_not's post was just not stated clearly.
    still-learning-about-chems-fc-cya-t67858.html#p559407
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    ... The SWG can be run at lower FC levels due to a few reasons, the biggest is the harsh environment within the cell. still-learning-about-chems-fc-cya-t67858.html#p559407
    Got it. Thanks!
    TF-100 test kit.
  20. Back To Top    #20
    x2rider's Avatar
    Jun 2011
    Bartlesville, OK
    212
    3 days later seeing the bottom.
    Not out of the woods yet but getting closer.
    [attachment=0:y38e8hbw]ImageUploadedByTapatalk1376701139.548720.jpg[/attachment:y38e8hbw]
    K-2006 Test kit
