Results 1 to 7 of 7
Thread: Greenhand of pool remove Leaves in pump strainer
    I just moved into a house with pool ,before that I never deal with pool.
    This morning I saw Leaves in pump strainer , I open the pump box to clean the strainer .
    This is an in ground pool. There is air in the pipe I think. How can I do?
    Thanks all.
    Re: Greenhand of pool remove Leaves in pump strainer
    I open the pump , it seen no water come from the pool . There must be air in the pipe between pool and pump.
    Help me
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Ok, I assume those "out of order" valves are stuck open? and go to the pool return eyeballs? When you open the pump strainer lid the water should drain back down the pipe, if water drains before you open the lid you have a leak somewhere, often is will just be the gasket around the strainer lid that needs to be lubricated with silicone lubricant (not silicone adhesive and not petroleum jelly), when the pump is turned back on it should be able to prime itself within a few seconds, if it does not prime within 20-30 seconds you may need to pour some water in before closing the cover to get it primed, some water will stay in the pump and some air will be there too.
    Ike
    thanks
    out of order means closed forever
    Isaac-1's Avatar
    SW Louisiana
    6,711
    So then how does water get back to the pool?
    thanks i have made it
    you r right the "out of order" pipe goes to pool
    and it not forever closed . it should forever opened
