Results 1 to 9 of 9
Thread: Pool Draining - What should I look for?
    May 2013
    Huntsville, AL
    31
    All,
    My pool liner is in need of replacing. I want to drain the pool, but the ground is really wet and saturated around the pool. Can I just simply drain the pool and ignore how much water is in the ground around the pool?
    Also, what type of pump should I use to drain this thing?
    Fred
    20'x40' ~33,000 gallon IG vinyl liner pool. Sand filter. Hayward AquaRite SWG ( T-15 cell )
    TF-100 Test Kit and Taylor K-1766 Salt Test Kit
    22,553
    Re: Pool Draining - What should I look for?
    Do you have a well point near the pool?
    Since you're replacing the liner it won't be as bad to drain it as it would if you were going to try and save it, but you could have some issues with fixing the floor for the new liner.
    Are you DIYing it or have you hired someone to do it?
    May 2013
    Huntsville, AL
    31
    I am planning on paying someone to do this. I have no idea what I am doing.
    Fred
    22,553
    They should have a plan for handling the water in the pool. There may be a well point near the pool from the install if the water table is normally that high.
    May 2013
    Huntsville, AL
    31
    The water table shouldn't be the issue. The issue is how long this pool has been leaking and how much rain we have gotten.
    Fred
    22,553
    If the water table isn't an issue then once it's drained and the liner removed it'll dry out pretty quickly. If it stops raining every day!
    May 2013
    Huntsville, AL
    31
    What would you use to drain the pool? I have 2 levels in my yard. The pool is on the higher side. I will pump from the higher to the lower. Just don't know what to use. I assume a rental pump would work.
    Fred
    Jun 2012
    Howell, NJ
    977
    Usually I think it works out cheaper to buy a submersible pump than rent. You can get one from Harbor Freight. I wouldn't have any idea what size to recommend, though.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Quote Originally Posted by TheDerf74
    If you have a main drain and a multiport, you can drain using your pump. Close the skimmers, open the main drain and set the multiport to waste.
    Support the site
