Thread: Pentair Intellifo VS pump in a Jandy system
    I just installed a new Pentair Intelliflow VS pump in my Jandy system. I was running my old Jandy 2hp filter pump 6 hrs a day at 3500 rpm, now I run my Pentair VS pump 14hrs a day at 1400 rpm and I'm saving money! My question is how do I program the Spa mode so that when I switch to the Spa mode that the Pentair changes speed up to 3450? Is there a way to program my Jandy PDA to change speeds on the Pentair? I should also mention that I installed the IntelliComm II interface Adapter to interface with the Jandy Control panel.
    11,000 gallons
    in-ground
    Hayward sand filter
    1 hp hayward energy flo rs
    Built in 2000 (aprox)
    Swim pure plus SWG
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Pentair Intellifo VS pump in a Jandy system
    Welcome to TFP!
    I hope you got this figured out...sorry you didn't get an answer! I know it is possible, but hopefully someone who knows how to do it will stop by to help.
