Results 1 to 12 of 12
Thread: My rigid backflush pipe solution
    May 2013
    Fort Lauderdale, FL
    423
    I went with 100' of 2" poly from home depot, a 1' section of 2" clear PVC with a vacuum break hose bib on a 'T', and a 1.5" MIP to slip using a double clamp collar. I need to make some sort of support for the 'T' fitting to prevent the clear hose from sagging. But when backflushing, you sure can see all the **** in the water! I plan to bury the hose going across the yard this weekend. The whole run is downslope so it should self drain.
    In retrospect, it would have easier and cheaper to go with 1.5", but bigger is better!
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    duckhunter27's Avatar
    Jul 2013
    Dannebrog, Nebraska
    59
    Re: My rigid backflush pipe solution
    Looks good.
    24ft x 52in Round AGP Heritage pool Aquamaster 19 in sand filter & 1 hp pump. Clear Solar blanket 12 Mil. TF-100 Test Kit. Pool filled June 3rd 2013 well water.
    May 2013
    Fort Lauderdale, FL
    423
    Thanks. I'm curious to see how the clear PVC hold up in the weather.
    CUTiger78's Avatar
    May 2009
    NoVA
    460
    The hose bib is a vent to allow the pipe to completely drain? Looks good.
    I've been tempted to built a lawn waterer for my backwash water. Maybe 20' of PVC from the filter to the yard, then a "T" w/ 20' of PVC on either side of the "T". Cap those lines & drill holes in them along their length to allow the water to spray out. Just a thought....
    36K gallon 42X22 gunite/plaster kidney-shaped IG;
    1 hp Hayward Super Pump (new in 2012);
    Hayward S244T sand filter w/ Zeosand (both new in 2009);
    175K BTU LAARS Lite2 LG natural gas heater; Polaris 380;
    TF-100 test kit.
    May 2013
    Fort Lauderdale, FL
    423
    Yes, the hose bib has a built-in vacuum break, so when the pump is turned off, initially the clear hose gets sucked closed, but the vacuum break allows air in and the line drains.
    May 2013
    NJ
    114
    I'm looking at the gray fittings where you have the 2" clear clamped on. Are they sort of like a barbed fitting for holding a hose on? Only difference being that it is actually just one ring or a single barb. If so do you have a source? I have one fitting that is 1-1/2" slip on one side and that type of connection on the other end and I was trying to find some more.
    17x37 IG vinyl, Grecian style, 20k gal, Hayward DE4800, Hayward Super Pump II 1 hp, Rainbow 320 Chlorinator, 6 Vortex 4x10 solar panels, Aquabot Turbo, Dolphin M5, loop-loc mesh cover
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Those look like the barbed fittings I used for a flex irrigation pipe project. I only found then in irrigation at Lowes. hD did not sell this product.
    -- Guy --
    May 2013
    Fort Lauderdale, FL
    423
    Don't waste time at the big box store. Here's what I used. http://www.plumbingsupply.com/insertfittings.html
    Good call on the vacuum breaker. Most people miss that. They do have vacuum breakers that work automatically. Such as this:
    http://www.salcoproducts.com/page/vv34b102a
    Or, this
    http://www.homedepot.com/p/Oatey-1-1-2- ... /100204205
    Support the site
    May 2013
    Fort Lauderdale, FL
    423
    Nice, what I like about those is they look like they'll flow more air than the little hose bib does. It's automatic too, but the clear hose sucks closed for a few seconds.
    May 2013
    NJ
    114
    I use the watts one on my solar panels and it does flow a good amount of air and is quick acting (1psi, I think). I would expect the one built into the hose bib has a much higher psi and flows less air causing the hose to collapse. I would bet the Oatey from HD even flows a bit more. I used the watts one being it is in a critical position up on my roof but for your backwash the Oatey would be fine if you didn't want the hose to collapse. Just spin that on grey connector so the valve mounts vertically and you may also need an adapter for the Oatey.
    May 2013
    Fort Lauderdale, FL
    423
    I wanted to follow up and say that the clear hose is still working just great. I never did support it, its been holding up fine by itself. The plastic is getting a little cloudy after being out all winter. I'm guessing I'll get another season or 2 out of it and replace the clear section again.
