Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: In your opinion who makes the best SWG?
    Aug 2013
    Oklahoma City, OK
    134
    If this thread is already covered somewhere I could not find it. I am new to the whole SWG thing and want to purchase in the next week or so. I found this and it seems to be a good deal by a well known company. Any opinion's are appreciated!
    http://www.poolsupplyworld.com/Hayward- ... AQRITE.htm
    20000 Gallon, Sand Filter, IG Plaster, Hayward Aqua Rite 40k SWG, TF-100 Test Kit, Taylor SpeedStir
    Apr 2013
    Westside LA, CA
    49
    Re: In your opinion who makes the best SWG?
    have the aquarite, very happy with it. was set at 25% for a covered16k pool and just measured 8ppm fcl so dialed back to 15%
    32x15 IG Borate+Salt, Pentair VS+SVRS, howard swim pure 40 SWG, Pentair 4000 48sqft DE, Mastertemp 300, Electric Pool Cover, Polaris P93, 4 Kids for Aeration, ;)
    38,235
    Some have more bells and whistles than others. Seems that all can have their problems.
    Aquarite is a good upper-middle of the road unit. I had one at previous house and installed one at current house.
    Jun 2011
    Long Beach, CA
    2,778
    The best SWG depends on many factors so there isn't one the should be considered the best SWG. If a pool has automation, you want one that incorporates the automation seamlessly. You want to take into consideration of your water flow, GPM, that you want to run at. Some cells require only 15 GPM to work such as an autopilot, and others will need 40 GPM. If you want to run at low speeds, if you have a 2-speed or variable speed pump, you need to make sure you have the proper flow. These are just a couple of things that influence which SWG is best.
    SWG's are not a set it and forget it type of system. If your water parameters are not ideal then all cells will have problems. Many people have no problems and get many years of trouble free service, while others like myself have had many electrical problems with their SWG's. Even with my problems I would not switch over to manually chlorinating the pool.
    Aquarite, compupool, autopilot are all respected SWG's on this forum. Make sure you get one rated for at least 40k gallons for your pool size.
    Aug 2013
    Oklahoma City, OK
    134
    Will do guys, thank you for your input. I will take all of this into consideration. Thanks again!
    Aug 2013
    Oklahoma City, OK
    134
    One other question. Is there anything else that I need to purchase besides what is listed in the link in my original post to make the switch over to salt easier? Thanks for the advice!
    Jun 2011
    Long Beach, CA
    2,778
    You will need some pvc, primer, and glue for the plumbing connections. You will also need wire, wire conduit, and maybe a couple ends for the wire conduit. If you are having someone else install it then they should supply these items. All of these items are cheap at Home Depot.
    Aug 2013
    Oklahoma City, OK
    134
    Sounds good. I had read another post where they had wired it in with timer. Is this the best way to go about it? I guess you want to make sure the swg is off when the pump is not running?
    Jun 2011
    Long Beach, CA
    2,778
    I have my SWG and pump wired to a timer and that insures that the SWG can not be on without the pump on. If you have a variable speed pump then it can get more complicated.
    Aug 2009
    SW Wisconsin
    518
    and if interested in saving a few bucks.I have a GOOD used unit advertised in the "Coffee Bar"...I switched over to a stenner dosing pump...so my SWG is up for sale.
    33' x 52" Swim and Play Inc. PARAGON AGP. Hayward H200 Heater. Hayward Power-Flo LX 1.5hp pump. Sta-Rite Cristal Flo T-210WF Sand Filter. Stenner 45M5 chlorine pump
    Aug 2013
    Oklahoma City, OK
    134
    flyweed - why did you decide to go back over to chlorine from swg? Just curious!
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Quote Originally Posted by Tanner M
    My AutoPilot is installed in "Manual Timer" mode. I control my pump using a Hayward OnCommand; essentially it's a fancy timer. The AutoPilot is wired on the same relay as the pump, so when the pump turns on, so does the AutoPilot. This is a specific configuration the AutoPilot is designed to work with.
    The AutoPilot can also be a timer, controlling the pump/heater, and that's probably how many (most?) people install it. In my case, I need a controller with solar logic/control, which the AutoPilot can not handle, so I use the OnCommand as the timer/controller since it can handle solar.
    If you just need automation control for the pump, there is no reason not to use the AutoPilot as your pump timer, and eliminate a piece of equipment in your setup.
    If the inclusion of a timer/controller matters to you, take that into account when considering the AutoPilot.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    Aug 2009
    SW Wisconsin
    518
    Tanner, it seemed I was ALWAYS adding salt to our LARGE pool 25,6000 gallons. After winter, when we'd refill to top off..or when it rained alot...salt PPM would always go down and need to be adjusted. It was just TOO much lugging salt bags..and I got sick of it....the SWG worked great, otherwise....but the Stenner is SO easy.....I fill up a 15 gallon barrel now and have the pump dialed in, so I maintain a constant 4ppm..and all I gotta do is top up the barrel once every 2 weeks. EASY.
    So the SWG must go!!
    Dan
    Aug 2013
    Oklahoma City, OK
    134
    Ok so I was reading installation manuals on swg installations. What is the reasoning for have the swg installed after the filter? My chlorinator is installed before the filter, why can't the swg be installed in place of it before the filter??
    38,235
    Because SWG release hydrogen gas ... while there is not really an ignition source, I still would not want explosive gas building up in my filter.
    Your chlorinator should not be before the filter either to reduce the corrosive effects.
    Aug 2013
    Oklahoma City, OK
    134
    Hmm... Learn something new on here as always! Here is a pic of the way my equipment is set up. I will do an after pic this weekend.
    38,235
    Well you certainly have PLENTY of pipe to work with after the filter
    Aug 2013
    Oklahoma City, OK
    134
    True, I guess I should just cut out the chlorinater and then add the SWG vertically?
    Aug 2013
    Oklahoma City, OK
    134
    Well here is the finished product. I ran into one problem which was not having enough pipe to be able to plumb the flow switch where the directions wanted me to. (past the filter). My plumbing is all 1 1/2" so by the time I added the couplers to bring it up to 2" there was no way I would have enough room for the the flow switch and the cell. It still works just fine but I wonder if I will run into problems down the road? Any advice is appreciated!
  20. Back To Top    #20
    38,235
    Does not look like you left the recommended straight pipe before the flow switch. Although if it is working, you should be good.
