Thread: How to use Quick skim and Aerator valves
    I have 2 valves from outlet of filter, please see attached picture, the quick skim valve is always Open and Aerator is Closed... is this OK? what is the purpose of these valves..
    11000 Gallons, Cartridge Filter, UG, Plaster, Shasta pool, filter model Hayward C4030, Pump Motor Emerson 1-1/2HP Full Rated EB2977T, Pump model Northstar SP4010NS
    38,547
    Re: How to use Quick skim and Aerator valves
    Have you turned them to find out what they do? That seems easier than us guessing.
    Likely the aerator will spray water into the air to aid in cooling the water and raising the pH if needed.
    Perhaps your pool has this: http://www.aamfg.com/quikSkim.php. If so, the valve that is turned on would let you turn the skimmer off if for some reason you wanted to do that.
    I agree with jbizzle, turn the aerator valve on and see what happens. It will probably be obvious.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
    Quote Originally Posted by danacc
    Ok Thanks, Yes I tried the aerator and I do see water coming into the pool from one Pipe... so why should I use this feature?
    When you turn the aerator on, does the water coming in "splash" or churn the top of the water where it enters? If so, using this will do 2 things: cool the water, and raise the pH without affecting TA at all. The first might be desirable if you have a really hot summer, and the pool water gets warmer than you would like. The second is desirable if you want to lower the TA. It lets you add acid which lowers both pH and TA, and then raise the pH while leaving the TA alone so you can add more acid to lower both of them again. (I don't know of any way to lower TA without also lowering pH, and of course, you don't want to drive your pH too low.)
