Results 1 to 13 of 13
Thread: Sand filter puffs up. No clue why.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    I was out of town for a week and my husband took great care of our pool. I cleaned the skimmer basket late Thursday night and all was great. I then checked on it again early Saturday morning and cleared leaves out of the basket. When I turned the pump back on I noticed a leak on one side of the filter where the top and bottom are joined and the band seals them together. I'm thinking I need to open it and reseal the gasket. That'd be okay. But, when I turned on the pump, the sand filter "puffs up" ever so slightly. Puffs up as in expands a little bit. Naturally, it frightened me. I disconnected the pump and sand filter. I have set up the intex pump and cartridge filter that came with my pool for now until I can figure out what was going on with my sand filter. The water flow seemed to be fine and I have found no blockages any where from skimmer thru to the return. I did forget to open the intake and return when I turned the pump on about two weeks ago . It was only for a moment and I turned everything off, opened the intake and return, turned the pump back on and everything was fine. Then about a week later was when I noticed the filter puffing up and leaking. Anyone have any ideas? Is my filter dead?
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Re: Sand filter puffs up. No clue why.
    It really sounds like the gasket or the band spring nut is shot.
    Have you checked both?
    The expanding of the filter you describe sounds plausible, assuming just enough pressure buildup despite the leak and loose band, to cause the top and/or bottom halves to splay outward.
    Filters have a max pressure rating and you could have exceeded that rating even in the brief moment that you had it on with the inlet and return closed. Damages like that can sometimes take a while to manifest, with problems not showing up right away.
    Thanks for reading... - Tony
    Da' Pool: Intex 15'x42" 3284gal AGP EasySet (Inflatable Ring) - (Summer 2014: 27' round EW /w 6.5' deep end @ 22,500gal)
    Pump & Cart Mod: 1000gph Cart. 5ft² - 2 nylons, 24/7 OP. Traps bugs/bits, lasts longer/cleans easier = Happier Pool Owner!!
    The Bible for a "Trouble Free Pool" life = PoolSchool, the BBB method a TF100 test kit(Recommend Kits Compared). - Cleaning a Sand Filter
    Water looks like GLASS, if yours doesn't...SLAM IT! Feels nice and never been happier!!! :D
    30,400
    My sand filter expands every time I turn on the pump....always has. I think you are just now noticing yours.
    Regardless, a leak is a leak and you will probably have to reseat/replace the gasket to get it stopped.
    22,537
    My filter also "swells" a little when I start the pump. They're plastic so they're going to expand a little under pressure.
    Fix the o-ring leak and it'll be fine.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Thank y'all so much! I freaked out thinking it'd blow like a pressure cooker. Was afraid someone would get hurt. I'll get a new seal when I get back into town and try again. Y'all rock!
    Angie M.
    22,537
    Be sure to lube it good when you put it back together.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Thanks. Oh, I know . Calls for silicone lube. I'm on line now looking for a new gasket. Stuck out of town again. May be a couple of days before I get to reassemle it.
    Angie M.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    Good job, stick with clear silicon or Teflon lube. Petroleum based products like vaseline are baaad juju!! They destroy the seal material.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Quote Originally Posted by y_not
    Thanks, I'd already checked the book. I'm one of those rare people that actually read the instructions. Takes some of the excitement out tho. You know, when things go haywire from winging it!
    Angie M.
    Jun 2013
    Manitoba, Canada
    153
    Umm........silly question, but is the filter head handle in the filter mode, or was it left on closed/off?
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Not silly at all. I had it set to filter and the water flow seems to be fine. Lots of water thru the return.
    Angie M.
    y_not's Avatar
    Jul 2012
    Redmond, OR
    1,086
    So did you get it all fixed up?
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Y_not, thank you for asking!
    I did get it fixed, up and running. I had noticed that the sand level was down a mite when I opened the filter up. So, I picked up a bag of sand to top'er off with and I went to the local home center store and got the silicone lube for the gasket. Cleaned the gasket as well as I could (man, that silicone stuff is sticky!).
    Went out, topped off the sand, reseated the gasket with plenty of silicone lube, then I reseated it two more times before I got it right . Put the filter back together, hooked the hoses back up and fired her off and IT WORKED! No puff up! It's working just like its old self!
    I still have the intex plunger valve on the return so closing that off was easy. But, when it came to the hose coming from the skimmer, I was well and truly stumped. I confiscated one of my dogs toy balls, filled it with water to see if that would block the outflow of water when I disconnected the hose. No go. The ball still wanted to float. So I thought and thought and came up with the perfect plug to use in the skimmer. The bulb from my turkey baster! Necessity, the mother of invention! I tied the hose end up above the pool water level but I needed a way to not lose a lot of water while I got the hose tended to. Anyway, the baster bulb was a perfect fit, I put it in the skimmer, filled it with water so it wouldn't float, turned it right side up so the open end slid right into the hole in the bottom of the skimmer. I then put the basket back in to hold the baster bulb in place and voila! I had a skimmer plug!
    Oh just a side note for those that may find it helpful, my other two favorite pool filter assembly tools are a "rubber wrench" and a "dead blow hammer". both are totally invaluable. The rubber wrench is adjustable and the dead blow hammer is SO much more effective than a rubber mallet which just bounces off the filter ring thingy that holds the top and bottom of the filter together.
    Angie M.
