Results 1 to 8 of 8
Thread: First time closing myself
    Aug 2013
    Michigan
    5
    Greetings all,
    I purchased a house last year (located in Michigan) that has an inground pool (18x36) with a Hayward Sand filter, one skimmer and two return jets. I hired someone to close it last year but will be doing it myself this year for obvious reasons I will not mention. I have been reading threads and researching closing options, and have some questions. My main question relates to how I can close the pool without draining it down below the jets.
    1. I have seen these one-way valves that replace the return jets (eyeballs) - Do they work? And if so, can the pump blow them out or do you need to use a blower from the skimmer? (I do not have a blower box but do have powerful shop vacs). Oh yea, I did purchase a Aqua-dor cover for the skimmer last year.
    2. Where do you poor the antifreeze in, in order to get it into the return lines? I am sure the guy did not do this last year, other than maybe pouring it into the filter cartridge near the sand filter. is that good enough?
    3. I don't recall him blowing out the drain line at the bottom of the pool. Perhaps he pour some antifreeze in somewhere, but in all, he only used 1 gallon for everything.
    Any advice or suggestions are most certainly welcomed! Thank you!
    18x36, center step, vinyl liner, 24k gal, 1hp Hayward Superpump, sand filter, YOC: 1993
    Jul 2012
    Herndon, VA
    419
    Re: First time closing myself
    just curious....
    how much did it cost to close your pool?
    $325 to close and $325 to open here in Northern Virginia.
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Aug 2013
    Michigan
    5
    $280 but I had to do all of the prep work (balance, shock, vacuum, pump it down, fill it up). I am a do-it-your-selfer but wanted to try to pick up some pointers last year.
    Just curious, I also live in Michigan and this will be my first time closing pool. When are you planning on closing your pool?
    27K gallon, IG vinyl pool, SD80 Sand Dollar sand filter-Michigan, 1hp pump
    38,528
    Ideally you should close when the water stays below 60 degrees ... it should not be based on a date:
    pool-school/winterizing%20and%20closing%20your%20above%20group%20pool
    pool-school/closing_in_ground_pool
    Aug 2013
    Michigan
    5
    I believe last year we closed it around Sept 25. But Like the last person posted, needs to be cool so the water temp is below 60.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yep the cooler the water the better.
    Jeff
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    This thread went a little off topic, so lets see if we can get back on course. Members please start a new thread if you have a question so the original poster's questions don't get overlooked and remain unanswered. Zea 3
    Quote Originally Posted by bigredcummins
    Greetings all,
    Love TFP? Become a
    TFP Supporter!
