Results 1 to 10 of 10
Thread: Adding bleach daily?
    Feb 2013
    Venice, FL
    23
    Recently switched to the BBB method after the pool store completely messed the pool up for a couple weeks.
    The question is; my CYA is around 55. I did the SLAM for a few days until I passed the OCLT. Now to keep my FC up I am having to add bleach daily. Does this sound right? Testing and adding daily? My pool sees full hot Florida sun all day.
    Thanks for all the good advice, pool looks great.
    IG Plaster~8500gal pool, ~300gal spa, Cartridge filter, ComPool LX100 controller, PentAir 320 In-Line Chlorinator, SwimTemp heat pump
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Adding bleach daily?
    Yes. You will have to dose with bleach daily to keep your FC in range for your CYA level. pool-school/chlorine_cya_chart_shock
    Jeff
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by hybridtrendz
    Absolutely. Testing and adding chlorine daily is an entirely normal part of owning a pool during the summer swim season.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    How much on average are you having to add daily?
    Jul 2012
    Herndon, VA
    419
    As a point of reference....
    I have a 12,000 gallon pool....and am adding about a quart of 8.25% bleach each day....
    roughly losing about 3.5 ppm of FC at my current CYA of around 35.
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Feb 2013
    Venice, FL
    23
    I am having to add about a quart daily. I try to keep FC around 7-10ppm. The FC goes down a lot during the day with the sun/heat
    Jul 2012
    Herndon, VA
    419
    if your CYA is 55, then your minimum FC level would be 4.5.
    Assuming your CYA was even 60, then your minimum CYA would be 5.....so, you should be targeting 8 as your dose level when you re-dose bleach every evening....
    Another thing I've noticed....
    even with being fairly certain that my pool is 12,000 gallons..... when I dose to get to a certain level, say FC - 7, I'll wait a couple of hours and re-test the water to find that my FC level is actually more like 8 or 8.5.
    Perhaps because the pool isn't always the same amount, due to rain, or conversly, evaporation.....
    just making the point....it seems a good idea to retest your water a couple hours after dosing it so that you can know your TRUE FC loss each 24 hours.
    thepiratemorgan's Avatar
    Aug 2010
    Central NY
    185
    Sounds completely normal to me. Full sun exposure and use (swimmers) will eat up the FC's. I "predose" my pool by a couple of ppm FC's if I know we are having a pool party. Yeah, I am that paranoid, and a snob...LOL
    14,600g / 24ft. Round Above Ground with Solar Cover
    18" Hayward Pro Sand Filter
    1 HP Hayward Powerflo Matrix Pump running 10am - 8pm
    Full Sun (when we get sun ... LOL): Approx. 10am to 7pm
    Using the Trouble Free Method, and loving it!! Arrrrrrrr!!!!
    Jun 2013
    Seguin TX
    192
    4 cups per day for my size pool. With cya around 40
    2017-Intex Ultra Frame 16x48 5000 Gallons
    Intex 2800GPH Pump with 14" Intex Sand Filter
    My Intex Pool Setup Video :Intex pool rises from the ashes - installing and leveling - EP-72 - YouTube
    38,546
    I moved a bunch of comments that turned into a thread hijack to HERE. While it started as related, best to keep the different discussions separate. jblizzle
