Thread: Pool/Spa/Spillover Help
    Jul 2013
    Puerto Rico
    76
    Hi!
    I'm installing a Hayward Aqua Plus system which will be able to control Pool/Spa/Spillover valves.
    The attached image is my current Valve setup coming in from the Pool and Spa and back out to them.
    My question is, given the setup, where should I place the 2 & 3 way valves to be controlled from the box?
    Thanks in advance for the help!
    JV
    Pool: 6,500gal Plaster (Pool & Spa), Capsule Shape, 25ft x 8ft, 3ft to 5ft depth
    Spa: 6ft diameter, 3ft deep
    Equipment: Hayward DE3620 Filter, EcoStar VS Pump, Aqua Plus Controls & SWG
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pool/Spa/Spillover Help
    Check out page 8 of the manual:
    http://www.hayward-pool.com/pdf/manuals ... Manual.pdf
    The two actuators go on the 3-way valves for the spa and pool.
    Here is another similar diagram:
    Mark
    Jul 2013
    Puerto Rico
    76
    Thanks!
    JV
    Jul 2013
    Puerto Rico
    76
    Sorry for the dumb question but, what is the Spa Makeup bypass in that picture for?
    38,246
    It sets the amount of overflow from the spa while in "pool mode".
    There are other ways of plumbing it, but that would allow you to easily set how much water overflows (or shut it off).
    You automation system has a spill-over mode, but that just means that all suction comes from the pool and returns to the spa to "clean" the spa. But if you always want a little spill-over then you either have to set the actuator stops to leave the spa return open a bit or put that loop in. With the former, if the spa is above the pool, the spa will always drain down to pool level with the pump off unless you added a check valve in the spa return.
