Results 1 to 13 of 13
Thread: Troubleshooting pool timer.
    Jun 2013
    Denver,N.C.
    6
    I have an intermatic pool timer that will not shut off the pool automatically. I have to shut it off manually. I replaced the timer and checked all the wiring. Still won't work. HELP PLEASE !!!
    15,000 gal. IG chlorine pool
    DE filter
    2 pumps
    30,431
    Re: Troubleshooting pool timer.
    I assume it is mechanical and not electronic. Are all the timing lugs tightened down?
    Jun 2012
    western NY
    1,561
    What model timer? Did it ever work right? What do you mean by "checked all the wiring"?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2013
    Denver,N.C.
    6
    The timer is an intermatic PB314E. It has post on it for wires. Yes all the contacts are clean and snug. They are the clip on type not the screw on.
    DE filter
    2 pumps
    Jun 2013
    Denver,N.C.
    6
    I forgot. Yes it was working fine until about a week ago and it just stopped.
    DE filter
    2 pumps
    22,553
    You replaced the timer and it still doesn't work?
    Did you replace the entire timer?
    Jun 2013
    Denver,N.C.
    6
    yes the entire timer
    DE filter
    2 pumps
    22,553
    Let me see if I get this right.
    It will turn on the pump but won't turn it off?
    Jun 2013
    Denver,N.C.
    6
    It will not turn on the pump nor turn off the pump automatically which is what it is for. I have a switch between the timer and the pump that I have to manually turn on or off.
    DE filter
    2 pumps
    22,553
    Has the timer ever worked?
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I read some place that intermatic timers have two different time trippers. Some are silver and some a gold, IIrC. One set is slightly longer than the other and the short ones don't work correctly in long arm switches.
    -- Guy --
    22,553
    This is an electronic timer, so it doesn't have trippers. I have read the same thing about the mechanical timers though.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Sorry...missed that. I have a Woods timer that is electronic but if you power up the timer in the middle of a on-cycle, it doesn't power on until the next on cycle. I don't know that applies to this situation
    -- Guy --
