Thread: Sealing Main Drain before changing MD valve
    Jul 2013
    Puerto Rico
    76
    Hi!
    I'm changing out 3 valves (Main Drain, Skimmer & Spa) valves at the Pumping Station.
    I need help/suggestions on covering/sealing the Main Drain so I can change the valve out with minor or no loss of water.
    Appreciate any help!
    JV
    Pool: 6,500gal Plaster (Pool & Spa), Capsule Shape, 25ft x 8ft, 3ft to 5ft depth
    Spa: 6ft diameter, 3ft deep
    Equipment: Hayward DE3620 Filter, EcoStar VS Pump, Aqua Plus Controls & SWG
    38,301
    Re: Sealing Main Drain before changing MD valve
    Just to confirm. Are the valves / pipes to be replaced below water level? If not, then the water will not leak out.
    22,550
    Is your equipment below the waterline? most inground pools the equip is above the water and therefore you don't need to worry about plugging the plumbing.
    Jul 2013
    Puerto Rico
    76
    They're above water level.
    Thanks!
