Thread: when to test after rain?
    Mar 2013
    NW GA
    69
    I know y'all say rain doesn't affect pool chemistry, but my pool seems to disagree.
    We got 4-5" rain in the past hour, and I wasted approximately 1300 gallons to prevent the pool from overflowing. I'll need to waste more when the rain stops to get the water level below the opening of the skimmer.
    Assuming it stops raining in the next 3 hours, is early evening still the best time to test? Or should I let the water turn over once or twice before testing?
    26900 gal IG Vinyl (18'x36', 3' shallow end and 8' deep end plus steps)
    sand filter and 2.7hp variable speed timer
    Jandy Ei SWG (2yr old)
    38,295
    Re: when to test after rain?
    It only takes an hour or so to mix the water up. So, an hour after you dump water with the pump running and the levels should be uniform enough to test.
    Mar 2013
    NW GA
    69
    Good to know.
    Thank you, sir!
