Results 1 to 7 of 7
Thread: ammonia test
    ammonia test
    I am going to do a ammonia test on my pool. Acouple of questions.. First can I just use the basic test that people use for aquariams? Secondly do I just forllow the diections as you would if you were testing tank water? Lastly, what kind of reading am I looking for? 0???
    23k gal IG Vinyl Liner
    Sand Filter Pentair Pump VS
    Electric Heat Ft Wayne Indiana
    Built 2012
    22,542
    Re: ammonia test
    Why are you doing an ammonia test? I thought you were holding FC. if you have ammonia you won't hold any FC until it's all gone.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: ammonia test
    Yes, you can use the ammonia test kit sold in pet shops/walmart, etc. Some pet stores will test the water for ammonia for free.
    But, as Bama said, the pool would not hold FC if ammonia was present.
    You're done SLAMing when:
    Re: ammonia test
    Im getting ready to do SLAM. My pool is not holding chlorine and I have 2 ppm CC. My CYA dropped quite a bit from last year and I want to do the ammonia test to make sure the CYA didnt turn to ammonia over the winter. Sorry I posted my numbers in a seperate thread.
    Built 2012
    22,542
    Re: ammonia test
    It would be better to keep all the info together so we would know the whole story. If you're not holding FC it may be a good idea to do the ammonia test.
    If you'll let me know which thread the other info is in I'll try to merge them so we'll have the complete picture.
    38,248
    Re: ammonia test
    Does it really matter if it is ammonia or not? The solution is the same regardless ... add chlorine until it holds and follow the SLAM process.
    Re: ammonia test
    ok good to know the solution would be the same!! FYI I did test for ammonia and didnt have any. Bad news, I retested CYA outside and got a 80. RRR Started SLAM last night, my threds are in "First Slam". Still trying to learn how to properly use the forum ( yes I did read pool rules)
    Built 2012
