Thread: Hello and first Question (Fence)
    Hello, just finishing a 40ft fiberglass in central Jersey and wondering whether in general deer fencing is up to code?
    We plan on doing a nice metal gate (up to code) and then the rest in deer fencing.
    Just looking for opinions and comments to defend the decision with the inspector.
    Thanks, Alex
    38,310
    Re: Hello and first Question (Fence)
    Welcome to TFP!!!
    I think you are going to have to be a little more descriptive as to what you mean by deer fencing. Although, it really does not matter what we think, it is up to the inspector and the local ordinances as to what is allowed.
    22,551
    Welcome to TFP.
    Is the fencing considered unclimbable? If it's not then it doesn't meet code in most places.
    In reality, the inspector has the final say and they're the one's you should be directing this question to.
    bigfunky's Avatar
    Jun 2012
    Wayne, PA
    137
    You need to check your local building code or you can call a fence company and ask them, they'll know what meets code and what does not.
    26,000 gallon gunite IGP with 50 sq ft Spa, Jandy VS FloPro 2hp Pump, Jandy DEV48 Filter, Jandy AquaPure SWG, Jandy AquaLink PDA-PS6 Controller, RayPak R406A Heater, Polaris 380 Cleaner, completed April 2013
    jv92red's Avatar
    Mar 2013
    SoCal
    117
    Just finished a pool and with our permit came an attached paper going over specific codes for gates and fencing for the homeowner. Like it has been said already the fence has to be non-climbable on the other side. The inspector also made a comment on my wood fence as he pushed and pulled on it and said I should shore it up with an additional vertical support but that he wouldn't not sign me off on it. I believe the fence has to be a minimum of 5 feet but this can vary depending on the area. Call your city and ask for the permit department then you should be able to get a hold of a city inspector that can go over the basics on the phone with you.
    Where I had the most restrictions was on my gate access: must swing out, must be self closing, latch must be lockable and 54" from ground, cannot have more than 2" opening from grade to bottom part of gate... I was looking for the part where it needed to be able to stop a bullet but could not find that requirement....
    15'x35' IG 16,500 gallons w/attached raised 18" spa continuous coping w/underneath spill and ledger stone wrapped, NPT mini pebble aqua blue w/2x pigment & abalone shell finish, 2"x24" travertine coping, 3x Jandy Color LED lights (2 in pool), Jandy Flo Pro 2HP VS pump, Jandy LXI (low NOx) 400K BTU heater, Jandy CL460 cartridge filter, Jandy AquaPure Ei SWG, Jandy Z4 automation with iAqualink and remote poolside PDA, 1,300 sqft Belgard Catalina paver deck with drainage, fire pit that matches the spa with travertine coping and wrapped in ledger stone, Elitewood insulated patio cover, Vinyl gates, back vinyl fence coming soon...
    TF-100
