Results 1 to 10 of 10
Thread: 20 Baum Muriatic acid prices
    Chad628's Avatar
    Jul 2013
    San Francisco Bay Area
    99
    My local Lowes has 20 Baum Muriatic acid for $7.28/ gallon. How does that compare with what everyone out there is paying?
    Petaluma, CA., 11K gallon IG pool, white plaster, Nautilus FNS 36 sq. ft. DE Filter, Jandy 1.5 HP variable speed E pump, Pentair Booster Pump with Polaris Vac-Sweep 280 pool cleaner, Jandy Laars LX Pool Heater, Remodeled (new plumbing, plaster, tile, coping, variable speed pump) January 2013. 400 gallon Artesian Island Spa (Ozonator/Chlorine), TF-100 test kit, SpeedStir.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Re: 20 Baum Muriatic acid prices
    Home Depot $10.99/ 2 gallons.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Be careful at Home Depot
    The brown box ones are the stronger MA for 2g/$11.98 but the KemTek is a weaker version for 2/$10.98. As you can see the brown box pallet is mixed. You need to look at the box you are buying and not trust the pallet tags. The KemTek is 14.5% . Real pool acid is 31.45% (20 baume)
    -- Guy --
    Chad628's Avatar
    Jul 2013
    99
    Thanks for that tip tech guy!
    tcat's Avatar
    May 2012
    Austin, TX
    731
    This is what I get: http://www.homedepot.com/p/Smart-2x1-Ga ... gks1cpJfN4
    I always check to make sure it's 31.5%. It's in the brown boxes.
    DIY chlorine feed
    BBB
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    That's about what I pay. Don't get the stuff by kemtec in the pool section. They have full strength in the paint department. Should be made by crown right next to the weaker smart muriatic for the same price.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    Here both Lowes and HD only have the weaker stuff in the pool section. The best I can do on 20 baume is Leslie's, 2 gallons for $10.99. It's about the only thing I ever buy at a pool store.
    chiefwej
    Yep I got 2 gallons of 20 Baum MA at Leslie's for $11.
    17,000 inground gunite pool finished June 2013. Pentair variable speed something or another. Polaris cleaner, inline rainbow chlorinator. Using trichlor until CYA reaches 50-60.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I guess my HD is different. Those two pallets were within the same aisle, across from each other. Hence the cross stocked pallets.
    -- Guy --
    tcat's Avatar
    May 2012
    Austin, TX
    731
    This is what's in my Home Depot box (at $10.98/2):
    DIY chlorine feed
    BBB
