Results 1 to 12 of 12
Thread: I always have to add CaCl - any ideas?
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    I tested my CH level last weekend (among other levels) and it was ~130 so I added some CaCl and re-tested yday and it was ~170. So I added more CaCl to get the level between 200 and 300. I will re-test in a few days to see where CH is. But ever since we began using the pool in July 2012 I find myself always having to add CaCl, which as I understand it is not normal. I would think after awhile the CH level would stabilize and I wouldn't need to continually add CaCl.
    Are there any ideas as to why I can't maintain CH above 200 consistently? It's a "standard" plaster pool, per my signature.
    18,000 gallon in ground, plaster - completed 6/29/12
    Jandy 340 sq ft cartridge filter
    Jandy variable-speed 2 HP pump
    Jandy LXi 400 heater
    Jandy Aqualink PDA-PS4
    30,432
    Re: I always have to add CaCl - any ideas?
    What is the CH of your fill water?
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    Good question, I will check that tonight. Is it possible this is going to be the norm for me depending on the CH of my local water?
    30,432
    Yeah, it's pretty straightforward...if your fill is low, your pool will stay low unless you add more.
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    OK, thought as much. I don't know why I didn't think to test the fill water's CH level. Thanks for the suggestion. I can also see why this would be more pronounced in the summer as I have more evaporation.
    Mar 2007
    San Rafael, CA USA
    12,082
    Perhaps you have a leak and the fill water is low in CH. The CH would not drop unless there was water replacement with lower CH water.
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    I wouldn't think I have a leak since the pool is just over a year old but it's not impossible. Being in Houston with our 100 degree days we can get quite a bit of evaporation (esp since I have no shade except for the house).
    Besides paying someone to perform a leak test, how can I determine if I have a leak? I assume I can turn off the fill water line for a day or two (we have an auto filler), estimate water loss and see if it's consistent with normal loss from evaporation? Our water bills are not outrageous or anything so there are no red flags from that.
    Mar 2007
    San Rafael, CA USA
    12,082
    See Leak Detection in the Pool School.
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    thanks. I will test the CH of the fill water and report back.
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    I never updated this. I tested my tap water and its CH is ~80, which would explain why I need to add CaCl to my pool more often. That's just the way it is.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    The bucket test would be a good idea.
    How are you testing? Pool store tests are notoriously unreliable...we strongly recommend doing your testing yourself with a good drop-based kit.
    Unless you have a leak or a gigantic amount of splash-out, CH will never go down, only up. It stays in the pool when the water evaporates.
    Jun 2012
    Louisville, KY
    266
    Calcium stays with the water, doesn't evaporate. My guess is you have a leak especially since you have an auto fill. Turn off the filler and do a bucket test, that will confirm if you're losing water to a leak and not just evaporation. Might want to do it ASAP to get any repairs covered under warranty.
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
