Thread: pH always rising
    May 2013
    New Jersey
    176
    pH always rising
    I'm at the point now where I have to add dry acid every week or so because of my climbing pH, even when there hasn't been a lot of swimming going on lately (not too much rain either).
    Our TA has been pretty steady around 70. I just lowered pH from 7.7 to 7.5/7.6 the other day.
    In the early season, when TA was about 100, our pH was stable, but then again, not much swimming going on at all then.
    Is this a normal occurrence to have to lower pH in the mid-to-end of the season, weekly? I'm now wondering if my rising pH has anything to do with my low TA and wondering if I need to correct TA at some point in order for pH to remain more stable??
    TA: 70
    PH: 7.5/7.6
    FC: 4
    7+ years, inground, 25,000 gallon, vinyl, sand filter.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: pH always rising
    Most pools tend to rise, perfectly normal. Do you have a salt pool? Im guessing no, but your sig doesn't say. Do you have water features? Both will speed pH increase. TA 70 isn't bad either. I do encourage you to use Muriatic acid versus dry. Dry acid used long term can contribute more sulfates to your pool. We are all about adding things with the least amount of side effects possible.
    Essential Links:
    May 2013
    New Jersey
    176
    Quote Originally Posted by Brushpup
    You're right. I didn't notice that I didn't put that I have a chlorine pool. No water features. I could understand why it was increasing when we were swimming a lot, but not sure why lately, when there hasn't been much aeration.
    I'll just leave the TA alone and continue to add acid when necessary. Thanks for the reassurance
    Mar 2007
    San Rafael, CA USA
    12,082
    If the pool water is warmer, then the rate of outgassing is somewhat faster.
    Smykowski's Avatar
    Sep 2011
    3,065
    As long as CSI isn't an issue, you could let it drift up to 7.7 or 7.8 and see if it settles there.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Just so you know, a salt pool is also a chlorine pool as the salt is converted to Chlorine. Just stay on it and you'll be fine. 7.5-7.6 is great if tou ask me.
    Essential Links:
