Results 1 to 7 of 7
Thread: Hayward skimmer mod
    Oct 2012
    Houston, TX
    186
    Hayward skimmer mod
    I discovered that there is no 'stop' on the thru the wall skimmer like there is on an in-ground skimmer. So when the pump turns off, the weir can flop in/out of the opening, letting previously trapped stuff float back into the pool.
    So I created my own stop. I used a window sash lock screwed into the face plate. It will turn in order to swivel out of the way so I can easily remove the weir for vacuuming.
    It made noise as the plastic weir whacked against the stop. So I put a felt pad on the door. Now it is silent. I doubt it will last long, so I plan to come up with another solution to the noise. we'll see how it plays out.
    Intex UltraFrame 14'x48in - 3,900 gallons. Intex 1600 GPH combo Sand Filter/SWG Hard Plumbed w/Hayward skimmer, suction & return. Borates.
    And... 15k gallon kidney shaped gunite 1975 vintage. Hayward DE3620 filter + Hayward 750 pump.
    TF100 Test Kit | Pool School | Pool Math
    30,414
    Re: Hayward skimmer mod
    That simple fix will likely last a very long time.
    22,544
    If it does rust you could get the same thing in a marine version in stainless.
    Apr 2013
    Battle Creek, MI
    298
    How did you happen to choose to put the skimmer so close to a post?
    I had that problem with my weir until it started raining here in BCMI and it seemed to never stop. Now my water level is up where the weir needs it to be to stay shut on its own!
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    Oct 2012
    Houston, TX
    186
    CeeElGee,
    The general area where the skimmer/pump needs to go is flanked by fence and neighbor's house. If I moved it towards the middle of the panel it's in, it would impede walking by that side. Same with if I moved it to the left, to the next panel. It would get in the way walking by that side.
    It seems fine and doesn't put any extra stress anywhere. There's still plenty of seam left between the skimmer and where the post is.
    I should have mounted it a bit lower. If I put the water where it should be (to the 2nd screw) it would be more prone to splash-out on the other side. 2nd screw is about 1/3 the way up the blue square in row 2 (from the seam). That would put water 1/2 from the seam on the other side.
    I'm going to either add add'l styro to the inside-lower portion of the weir or lower the whole skimmer 1" and live with an open slot at the top of the skimmer. If supported by hard plumbing (bottom 90-degree turn near the ground with a shim under it) I don't think it'll be a structural problem. Don't know. Still thinking it through.
    Apr 2013
    Battle Creek, MI
    298
    Quote Originally Posted by hyperionguy
    Yeah, I went way high too, but I like my water level high. Except when my brother-in-law gets too rowdy with my kids and splashes a bunch of it out! I need him right now. Another 1.62" of rain here in the past 24 hours and my pool is full. Won't even skim properly right now. Too lazy to do anything about it though.
    Thanks for sharing!
    Intex Ultra Frame 18' x 52"
    Intex 3000 gph Sand Filter Pump, Intex Salt Water System SWG
    Hayward Thru Wall Skimmer and stock return line
    Two Hayward I lets
    Florida/Alabama
