Results 1 to 9 of 9
Thread: 1st test kit results - how often to dose /w bleach?
    Guest
    Hi,
    Got my test kit recently and the pool seems to be running pretty well and is clear. Here are my 1st measurements:
    FC- 6ppm
    CC- 0
    TA- 170 ppm
    CYA - 60 ppm
    pH - 7.8
    So based on the CYA/FC chart my target is about 6.8ppm, so I could top off the pool with some bleach. And I think I could let NY's acid rain take care of the pH over time. But how often should I expect to have to add bleach assuming normal summer east coast summer weather and very light bathing load (only go in maybe twice a week in the pool)?
    Thanks
    Jul 2013
    Columbus, Ohio
    114
    Re: 1st test kit results - how often to dose /w bleach?
    Quote Originally Posted by pleasantpool
    Hi,
    FC- 6ppm
    CC- 0
    TA- 170 ppm
    CYA - 60 ppm
    pH - 7.8
    Thanks
    My CYA level is similar to yours but my pool is a little smaller. I loose 3 - 4 ppm due to the sun. Check your level in the morning and evening and see how much you lose. It should be fairly constant assuming you are not also fighting algae.
    16,500 gallon, 18" x 38" Grecian; IG Vinyl, Hayward DE
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    You'll probably have to dose chlorine everyday so you don't fall below min. FC. You'll get to know your FC consumption the more you test. Add your chlorine in the evening when the sun is no longer on the pool then you'll be good for the next day
    That's how I do it.
    Jeff
    Guest
    3-4ppm loss per day? wow
    30,432
    I think the forum-wide average is closer to 2 ppm. I'm about 2.5 ppm
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yea I'm anywhere 2-3 ppm.
    Jeff
    Jun 2013
    SpringHill FL
    415
    Daily im around 2-3ppm loss
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Jul 2013
    Columbus, Ohio
    114
    It sounds like I need to do an OCLT since my usage is so much higher.
    Jun 2013
    SpringHill FL
    415
    Could be just sun vs a lower cya or organics a oclt will tell you
    Nathan
