Thread: CH question
    CH question
    My CH level is continuing to creep up for some reason. About 6 weeks ago it was 280 and now it is around 350. In that time period other than adding bleach, muratic acid, and the occasional baking soda, I haven't added anything else. What is causing it to rise and how high is too high before I need to replace water. Also if I continue to add water due to evaporation, shouldn't this drop CH and CYA?
    Thanks for any help.
    10,000 Gallons/Cartridge Filter/In Ground/Plaster
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: CH question
    1. Is your pool new?
    2. Have you tested your fill source?
    Jul 2013
    Columbus, Ohio
    114
    Re: CH question
    Quote Originally Posted by Fletch03
    Have you tested your fill water for CH? CH and CYA only drop when you replace liquid water. Evaporation leaves CH and CYA behind in the remaining water. I don't think your CH is cause for concern but I know more about CYA than I do CH in a plaster pool. Mine is vinyl and I don't worry about CH too much.
    Compare the CH level of your fill water to your pool just to see if you fill water is higher.
    16,500 gallon, 18" x 38" Grecian; IG Vinyl, Hayward DE
    Re: CH question
    Yeah the pool is about 2 months old. I'll check fill water but when I originally filled up the pool I want to say CH was around 160 or so, so I don't think it is fill water.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: CH question
    Not necessarily. Water evaporates, but CH does not. When you refill, you are adding some additional CH even if your fill water is lower in CH than your pool water. The water again continues to evaporate, you top off, and the cycle repeats. What you are experiencing is quite common. I experience the same thing. MY CH is the same as yours and is no cause for concern (it is in the high end of the recommended range). Still worth testing the CH of your fill water to see where it is at. The CH will drop if rainfall picks up as rain water has no CH.
    Re: CH question
    The new plaster may be adding CH. Use the pool calculator, and see what your CSI is. You want to keep this slightly positive to protect your new plaster while it cures. Yours isn't rising very quickly though; if your CSI is on the positive side, just make sure it stays that way.
    Outdoor 14,000 gallon IG plaster pool built in 2000 with spillover spa, 2 hp WhisperFlo pump with MagneTek motor, Sta-Rite cartridge pool filter with 300 ft2 filtration area and 0.33 gpm/ft2 filtration rate, Aquabot Rapids 4WD robotic pool cleaner, Raypak digital gas heater, and Intermatic mechanical timer located in the Dallas-Fort Worth metroplex
