Results 1 to 13 of 13
Thread: household bleach (6%) or pool store bleach (12%)
    Jul 2012
    Whidbey Island, WA
    398
    Was in pool store today.
    12% bleach is $10 / gal. Household bleach at grocery stores is $2.50 / gal. Pool store guy said household bleach has other stuff like detergents etc and raises TDS and should not be used. Anything to this? Household bleach not as good as 12% pool store bleach?
    Thank you
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Re: household bleach (6%) or pool store bleach (12%)
    Regular bleach is now 8.25 % and is fine to use. Just make sure to get Regular bleach that specifies sodium hypochlorite ...8.25 % on the label. Make sure that you do not get scented, outdoor, HE, splashless or other special use bleach.
    10 dollars per gallon is way high for 12 %..
    Support the site
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I use the regular bleach and no problems. Don't use the scented or splashless, just regular bleach. Only difference I know of is the concentration percentage of chlorine.
    Jeff
    Jul 2012
    Whidbey Island, WA
    398
    Quote Originally Posted by JamesW
    I suspected same. Got it. Thanks.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by engrav
    Not a (you know what) thing. Just make sure you are using plain, unscented liquid bleach without any thickeners added.
    TDS is pool store BS for not knowing what they are talking about and is often used to goad you into buying chems from them. TDS by itself is a meaningless measure as it is made up of several components. One pool could have a TDS of 1,800 and another could have a TDS of 1,000. Which pool has a better water chemistry? Cannot tell from TDS.
    foobert's Avatar
    Jul 2013
    Bay Area, CA
    143
    Wow! $10/gal of 12% = $0.651/oz NaClO -- a terrible price.
    $2.50/gal of 8.25% = $0.237/oz NaCLO. A decent price, but, not great.
    See this thread bleach-prices-2013-t58266.html
    ~john
    24.5K G, pebble, SuperFlo VS 1.5, 48sq DE filter, Hayward H250FDN, Autopilot RC-52, Poolvergnuegen & 3 daily swimmers in season.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    That is pricey. The last time I bought 12.5% I paid 2.99 a gal.
    Jeff
    Mar 2007
    San Rafael, CA USA
    12,082
    Also, the amount of salt is the same per FC in 6% or 8.25% bleach as it is in 12% chlorinating liquid ("pool store bleach") so he isn't even right about that. For every 10 ppm Free Chlorine (FC) added by bleach or chlorinating liquid, it also increases salt by 8.5 ppm immediately and by another 8.5 ppm when the chlorine is used/consumed (all sources of chlorine result in the 8.5 ppm increase in salt when the chlorine is used/consumed -- bleach and chlorinating liquid add additional salt upon addition).
    Jul 2012
    Whidbey Island, WA
    398
    Quote Originally Posted by chem geek
    Ok, will keep on exploring. Maybe out here in the woods, with the pool not checked every day, tab feeder is the only practical option. Or tab feeder to keep it at baseline and then bleach or granules pulse to get it higher when being used.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    You would need to be careful about the tabs and granules, as most will raise your CYA along with your FC. The exception being calcium hypochlorite, which has it's own problems.
    Best to adjust your dosage of liquid chlorine upward to account for the length of time between test and dose cycles.
    Do you know your CYA level?
    Can you use a liquid chlorine dosing pump? Either a commercially made system, or build your own.
    Jul 2012
    Whidbey Island, WA
    398
    Quote Originally Posted by Charlie_R
    today FC4 TC4 pH7.8 TA90 CH260 CYA30-(or maybe less, hard to tell at that level) water is clear
    would seem pulses of granules will be Ok for a time since there is lots of CYA headroom, and maybe even need a little more CYA
    I think manually daily putting in liquid chlorine will not work out here, gonna have to be some compromise of the BBB plan, will explore the chlorine pump
    thank you
    AaronGo's Avatar
    Dec 2011
    Houston, Texas
    130
    Quote Originally Posted by foobert
    man, I must be looking in the wrong places. I have a difficult time finding 8.25% for less than ~$3/gal in Houston. I need to call around some and find a better price.
    Target has been running a buy 3-get 1 free sale on their bleach so I stocked up. Comes to $0.213/oz.
    18,000 gallon in ground, plaster - completed 6/29/12
    Jandy 340 sq ft cartridge filter
    Jandy variable-speed 2 HP pump
    Jandy LXi 400 heater
    Jandy Aqualink PDA-PS4
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    Target is where I'm headed this afternoon...down to 1 unopened jug and attempting a slam here...neeeed. more. bleach.
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
