Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Pump upgrade
    Pump upgrade
    Hello, looking to upgrade my current pump (WhisperFlo WFE-8/2HP/Service Factor 1.3/2" pipe). Pool is 20x40 36,000 gallons. Please advise on a good replacement model and if possible a good source to purchase. I am assuming variable speed is preferred?
    Thanks
    36,000 Gallons
    Whisper Flo WFE-8 2HP pump, Hayward DE6020, Purex minimax 400
    IG - 20 x 40 - 3.5 shallow - 8.5 foot deep, IG attached spa
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pump upgrade
    Welcome to tfp, maitai777
    Why do you want to upgrade?
    Do you have any high volume water features the pump needs to run, such as waterfalls, spa jets or deck jets?
    Quote Originally Posted by maitai777
    Not necessarily. What is the cost of energy where you live?
    Re: Pump upgrade
    The pump is making a high pitch noise and I have been told the bearings are on the way out. I just bought the house and I have also been told this particular pump draws around 1700 watts so I would like to lower my bill. I have an attached inground spa which the pump can filter/heat if I switch 2 valves. I am in San Diego, CA so I guess the cost of energy is probably the highest in the nation?
    Thanks for your help.
    36,000 Gallons
    Re: Pump upgrade
    anyone?
    36,000 Gallons
    22,543
    Re: Pump upgrade
    I would suggest that you just replace the motor with a 2-speed model. The other option would be to go with the Intelliflo.
    Re: Pump upgrade
    36,000 Gallons
    22,543
    Re: Pump upgrade
    That's the one.
    Re: Pump upgrade
    are there other intelliflo models to consider or did i just happen to pick the right one?
    36,000 Gallons
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pump upgrade
    The WFE-8 draws over 2300 watts on high speed for typical 2" plumbing, not 1700 watts. But if you don't need the high flow rate for a spa or other water feature, you might consider downsizing the impeller and motor.
    Also for CA, a VS might not be a bad choice. It depends on how much money you want to spend up front vs save down the road.
    Mark
    Re: Pump upgrade
    Ok decided to go with the Intelliflo 011018. Any suggestions on the best place to purchase?
    Based on the attached photos, any advice on installation? Fittings needed?
    [attachment=2:56sr5est]pump1sm.jpg[/attachment:56sr5est]
    [attachment=1:56sr5est]pump2sm.jpg[/attachment:56sr5est]
    [attachment=0:56sr5est]pump3sm.jpg[/attachment:56sr5est]
    36,000 Gallons
    Apr 2013
    Sacramento, CA
    2,769
    Re: Pump upgrade
    If you are an SDG&E Customer you may be eligible for a $200 rebate on a new pump
    Look Here: http://www.sdge.com/upgrade-and-save
    Most California utilities will give you a rebate on the purchase of a new VS pump
    22,543
    Re: Pump upgrade
    They didn't do you any favors on that plumbing, did they?
    From what I can see, the Intelliflo won't fit in the same place as the other pump. I don't think there's enough room under and around the piping for the drive to fit. And if it did, you couldn't access it.
    I would turn the pump 90º so the motor would point toward the filter and replumb the pad to it.
    Re: Pump upgrade
    gwegan - thanks for the info on sdge - hopefully that will happen!
    bama - no kidding - that plumbing is a mess. what to you mean by replumb the pad? also what do you think about automatic valves instead of my manual valves? am thinking about getting the attached spa filtered once in a while without having to manually switch them. can automatic valves wire directly to the intelliflo or do i need another control unit?
    36,000 Gallons
    22,543
    Re: Pump upgrade
    In order to automate valves you need an automation system. The IntelliFlo drive isn't designed to operate anything except itself.
    Adding automated valves is a good idea. If you add an automation system you can control the valves and the pump speed depending on what mode it's in.
    Re: Pump upgrade
    ok - any input on a good automation unit to connect to the intelliflo?
    36,000 Gallons
    22,543
    Re: Pump upgrade
    Since you're getting the Intelliflo you should stick with Pentair for the automation. Either the Easytouch or the Intellitouch.
    Re: Intelliflo XF
    So is the general consensus that if you have 2" then don't go with the XF?
    36,000 Gallons
    IntelliFlo XF and 2" plumbing
    So the XF will work out ok with 2" plumbing? Trying to decide between the 010118 or the XF....
    36,000 Gallons
    Re: Pump upgrade
    Unless you have extremely high flow rate requirements, you should get the regular IntelliFlo and not the XF, and when you do have extremely high flow requirements you should have pipes that are larger than 2". The XF will sometimes work on 2" plumbing, but there can be priming issues.
  20. Back To Top    #20
    Re: Pump upgrade
    ordered the 011018 from pool supply world - thanks for all your advice.
    36,000 Gallons
