Thread: fc level for swg
    Feb 2011
    Petaluma, Ca
    665
    fc level for swg
    I read that the fc level should be between 3 - 5 for a swg, is there a problem with it being a little higher than that? Here are my tf-100 test results:
    fc 8
    cc 0
    tc 8
    ph 7.4
    ta 80
    ch 390
    cya 50
    salt 3000
    temp 86
    The water looks perfect at this level, when the fc was around 4 it would get a slight cloudiness with heavier use, but at 7 / 8 where its been for the past month it stays crystal. I know this may be causing more wear to the swg so I will prob adjust down to 45% run time from 50% on the cell to lower it a little, pump run time is 12 hrs.
    I keep adding cya, but due to my auto cover when there is a lot of people, water splashes into the vault so the cya level keeps dropping, I added 8 pounds in the last few months. I guess if I really raised the cya to 70 - 80 the fc level of 3 - 5 would keep the water clear?
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: fc level for swg
    If you know you will have heavy use, you can bump FC w/bleach/liquid chlorine or turn up the SWG.
    Having the CYA level at recommended range would help maintain FC at lower level. However, you still need to be aware of heavy bather loads and the impact that will have on the FC.
    You're done SLAMing when:
    Feb 2011
    Petaluma, Ca
    665
    Thanks, I was adding some cl manually at times as you suggested, but for the last few weeks its been pretty steady at 7 / 8. We had about 10 kids last sunday and the next day it was still crystal without adding additional cl. I guess it makes sense to lower the cl level and then bump up as required as opposed to keeping it higher all the time.
    30,400
    If you don't like tweaking your SWG back and forth, manually adding some Clorox prior to the party is awfully convenient and it will drift down on it's own in a day or so.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Pool Calculator says 2-8 for SWG @50 CYA. So no problem running it higher.
    If you raised CYA a little, to the recommended 70, you could keep it up there and run the SWG even less.
    Feb 2011
    Petaluma, Ca
    665
    Thanks for the replies, I'm going to raise the cya and lower the swg setting, then just add manually as required.
