Results 1 to 8 of 8
Thread: Label to CYA mixing bottle came off
    Jun 2013
    Louisville, KY
    65
    I don't know how much pool water or R-0013 to use now. Anyone know?
    21ft round Doughboy AG, 9,300 gallons
    22 inch ClearWater Sand Filter
    1 HP Hayward Power Flo Matrix Pump
    Install 6/16/13
    TF-100 Test Kit
    Re: Label to CYA mixing bottle came off
    50-50. I typically mix in a measuring cylinder.
    NW Houston: 25K gunite pool & spa and pebble finish. Travertine deck.
    Pentair pumps: VS (pool); 2HP & 1.5HP (water features); booster pump
    400K gas heater; 520 cartridge filter; IntelliTouch + 8 function wireless
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    It is a 50/50 mix. Fill your mixing bottle to the neck and pour it into a measuring cylinder to find the volume, divide the volume in half, pour the half volume into the mixing bottle and mark the level with a sharpie.
    Love TFP? Become a
    TFP Supporter!
    Jun 2013
    Louisville, KY
    65
    I'm guessing its more than 7ml. I tried that for both but it doesn't even fill the vial up. My CYA is on the lower end so I need more than that. I'm hoping it reads at least a 30 but the vial only filled to 50 and them I ran out. I wonder if I can poor it all back into mixing bottle and add more water and r-0013 to it instead of starting over.i hate to waste the chemicals.
    Install 6/16/13
    TF-100 Test Kit
    Jun 2013
    Louisville, KY
    65
    Awesome, thanks!
    Install 6/16/13
    TF-100 Test Kit
    Aug 2011
    Southern California
    188
    Quote Originally Posted by Iwilk
    In my Taylor 2006 kit the mixing bottle shows 7ml for pool water and 14ml for chemical. There is still head space in the bottle for mixing/shaking.
    With 14ml being plenty of finished product to get your CYA reading. If you're mixing more, then you're wasting product.
    30,424
    Well, that stinks! PM me your name and address and we'll send you a new bottle. Those labels are supposed to be pretty much waterproof.
    Jun 2007
    New Jersey
    653
    Quote Originally Posted by Hawk
    The Taylor and TFT use the same reagents but different vials and mixers. The TFT test is larger and reads down to 20 instead of 30 and is easier to use and read, and, I assume, more accurate. I use the TFT CYA test instead of the one that came with my Taylor kit.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
