Results 1 to 11 of 11
Thread: Closing and packing Ultraframe AGP
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    I know we're only at the beginning of August, but I'm a school teacher, and I've already gone back to work.
    My wife is concerned that I'm not going to have time to vacuum and maintain the pool once the students come back (which is probably true).
    We decided to take the pool down this year, so I can do more work under the pool next spring, after that, we'll probably leave it up.
    ANYWAY, I know I've seen steps and stuff about how to clean, care, and pack AGPs but I can't find them.
    Can anybody share what I need to do, or share the right link?
    Thanks
    16x48 Intex Ultraframe vinyl AGP, 2150 gph sand filter/pump (Intex SF70110), Hayward Skimmer, TF-100 test kit
    Re: Closing and packing Ultraframe AGP
    Others may have more tips or may know the link you are referring to. All we do is drain it then I use a shop vac and immersion pump (I think that is what it is called) to get out the stuff below the drains. Then we either leave it up for a day in the sun or use a leaf blower to get it all the way dry on the inside. Then disassemble and get the bottom dry. We have a through-wall skimmer we take out but I think others have left it in. Put the metal parts in one big trash can on wheels. Put the liner in another trash can on wheels and store in the garage. That's all we do.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    What do you do to the water prior to draining?
    Also, you don't do anything else to the liner? No problems?
    Jun 2013
    Manitoba, Canada
    153
    What would you do to the water if your draining it? Before draining, give the pool inside a good scrubbing and then drain away. Get the last bit our with the shop vac, and then let it dry for a day or 2 before folding it all up.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    You shouldn't need to do anything to the water. Just make sure the liner is clean and dry before you fold it up.
    Love TFP? Become a
    TFP Supporter!
    Well, I do make sure the ph is within range and the FC is close to zero. That's it though. Nothing special gets done to the liner other than ensuring it is a dry as possible.
    Jul 2009
    S. California
    157
    Quote Originally Posted by crek31
    ...Put the metal parts in one big trash can on wheels. Put the liner in another trash can on wheels and store in the garage. That's all we do.
    Great idea! I was looking at those very large and expensive Rubbermaid boxes at Home Depot. A trash can would be perfect for the long side posts, etc...
    Thanks!
    18'x 52" Intex Ultra Frame AG pool
    7100 gallons
    1600 Intex sand filter
    TF-100 test kit
    BBB method for four seasons
    Former 18' Easy Set owner
    Jun 2012
    Pennsylvania
    44
    I also sprinkle baby powder all over our liner before folding it up to help absorb any left over moisture we may have missed and to prevent the vinyl from sticking. I'm not sure if it's absolutely necessary, but it worked well for us so that is how I will be taking it down again this year.
    16'x48" Intex Ultra Frame Pool
    Intex 2650gph Sand Filter Pump
    Intex SWG
    Jun 2012
    MA
    347
    I store mine in a clam shell cargo carrier.
    Chewbubba's Avatar
    Jun 2012
    Russellville, AR
    127
    Quote Originally Posted by wozzukes
    I remember reading something like this last year here on the these boards. Baby powder inside and out, or just the inside?
    Jun 2012
    Pennsylvania
    44
    I sprinkled it everywhere that vinyl would be touching vinyl. I sprinkled the entire inside, then put the walls down, then as I folded each side over I would sprinkle some more on the outside. I probably went a bit overkill, but it's cheap and worth it to not have any sticking issues.
    Intex SWG
