Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Power Light on Chlorinator
    Jul 2010
    Longwood, FL
    151
    Suddenly on my AquaRite Salt Chlorinator Power light went off.
    When I start the pump GENERATING comes on for while & that too goes off
    Any idea ?
    15,000 Plaster IG Pool
    AquaRite SWG, C1750 Catridge filter
    G3 Vaccum, T-100 Kit
    22,543
    Re: Power Light on Chlorinator
    Sounds like you need to read the aquarite thread.
    Jul 2010
    Longwood, FL
    151
    Sorry did not knew there is separate thread .
    Thanks
    Jul 2010
    Longwood, FL
    151
    Can you please send me the link
    Thanks
    Jul 2010
    Longwood, FL
    151
    Mod Edit: Please do not start multiple threads on the same topic. Thanks, moderator linen
    My Power light is not LIT,
    When pump starts the GENERATING light come on for few minutes then that too goes OFF
    Thanks
    Jul 2010
    Longwood, FL
    151
    Found it thanks
    Jul 2010
    Longwood, FL
    151
    No one is replying on Chlorinator thread.
    Thanks
    Remove the front cover plate and check the inrush current limiter on the circuit board. Quarter size black disc.
    Support the site
    Jul 2010
    Longwood, FL
    151
    What do I need to check on this
    See if it's cracked or burned. Turn power off to unit before removing cover plate.
    Support the site
    Jul 2010
    Longwood, FL
    151
    I see a black color round shape with two legs on it , it has VERY tiny crack on it ?
    IS that normal , IF not what next
    If it's cracked, then it's probably bad. It can be replaced. Is your unit under warranty? Can you post a picture of the limiter?
    Support the site
    Jul 2010
    Longwood, FL
    151
    I will take picture, No its not in warranty
    I think that the limiter is most likely the bad part. This should be the part you need:
    http://www.digikey.com/product-detail/e ... ND/2614388
    http://idoneitmyself.wordpress.com/2009 ... lightning/
    http://www.youtube.com/watch?v=TOJ6WcW9CYs
    If you are not good are soldering components, you should be able to find someone local who can, such as a computer, TV or electronics repair shop.
    Without being on site to check the unit, I can't be sure that this is your problem. You will have to decide if it's worthwhile to try this repair.
    What are the first 4 characters of the serial numbers on the power box and cell?
    Support the site
    Jul 2010
    Longwood, FL
    151
    Perfect , thanks for info , I am ordering this now
    Make sure to document where the wires go before removing the circuit board, including taking a few pictures. Use wire nuts on the power supply wires while the circuit board is out. Make sure that you maintain good chlorine levels during this time. Liquid chlorine is a good choice.
    http://www.youtube.com/watch?v=tPL_YnvWumk
    Also, note that older models used a smaller current limiter with a different part number. (SL32 2R025) (570-1062-ND). New limiter is AS32 2R025. Check the part number on your limiter to make sure that you are getting the right one.
    Support the site
    Jul 2010
    Longwood, FL
    151
    Noted all, Any tip on where to buy solder iron & solder wire ?
    22,543
    The Walmarts around here have solder and irons. Radio shack has them too.
    Jul 2010
    Longwood, FL
    151
    Got the Digikey part , Do I need to take out all the wires from main PCB to take it out ?
    Any video ?
  20. Back To Top    #20
    Remove the wires connected to the circuit board. Be sure to carefully note where they go. Turn off power to the unit first.
    Support the site
