Thread: First chlorine test, Taylor K2006
    Mar 2013
    Woodbury, MN
    16
    When I'm adding R0871 to determine FC I counted 8 drops and the tube turned clear. Then while I was grabbing the R0003 the tube went back to slightly pink.
    So, my question is whether I stop counting drops when it turns clear while swirling or do I keep adding drops until it stays clear?
    20K gal, IG vinyl, intelliFlo variable speed pump, SD60 sand filter
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: First chlorine test, Taylor K2006
    http://tftestkits.net/Test-Kit-Instructions-10.html
    10 ml sample.
    Add scoop of R-0870.
    Swirl.
    Count drops of R-0871 until clear, while constantly swirling.
    Multiply number of drops by .5 for FC ppm.
    Add R-0003.
    Swirl.
    Count drops of R-0871 until again clear.
    Multiply drop count by .5 for CC ppm
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Quote Originally Posted by Ace7211
    If left sitting on the counter, the sample will turn pink again one or two minutes after the test is completed. This is normal. extended-test-kit-directions-t25081.html
