Thread: Which sand filter for Summer Escape pool?
    New Member. May be on wrong site. What sand filter should I use to for a Summer Escape pool, 18x48. Pump already gone bad on the one that came with pool. Thanks
    Aug 2013
    Hot Springs, AR
    3
    Re: Which sand filter for Summer Escape pool?
    From what I have read so far on here everyone with your size pool likes this one
    http://www.vminnovations.com/Product_87 ... -Pump.html
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, samtech
    The intex 2650 sand filter has gotten good reviews on here. I would get that over the 1600 that was pointed out above, since your pool is a little bigger and the 2650 does a better job if you use a suction side vacuum.
    I would avoid any that have the swg "built in" since they never fail at the same time.
    Thanks for the info.
    DigbyAllen's Avatar
    Westchester, NY
    113
    +1 for the Intex 2650. I own one and really like it.
    PS you are on the right site. Best pool site on the web!
    Jim
    Intex 15' x 42" -- 4,000 gallons
    installed August 2012
    Intex 2650 sand filter, Hayward skimmer
    TF-100 test kit, TFP method
