Thread: SLAM with SWG
    lee872's Avatar
    Central Massachusetts
    59
    SLAM with SWG
    This is my first time SLAMing with my SWG. Should I keep the SWG running when I add bleach, or turn it off? I'm wondering if the high chlorine level will damage the cell. Thanks!
    35,000 gallons - inground vinyl liner -- sand filter - 1 HP, 50.76 GPM - Aqua Rite T-Cell 15 SWG - Dolphin Apollo Plus - TF-100
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: SLAM with SWG
    The cell is fine with the chlorine levels, but we recommend turning it off during the whole SLAM process and saving the runtime/life.
    38,262
    Re: SLAM with SWG
    Leaving it off also lets you get a better feel for the chlorine consumption.
    lee872's Avatar
    59
    Re: SLAM with SWG
    Thanks -- I took your advice and turned it off.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: SLAM with SWG
    You can also use the SWG to help maintain FC Shock levels during the SLAM process.
    This can be helpful especially if you are not able to babysit the pool thru the process.
    Make sure to turn SWG OFF before performing the OCLT.
    You're done SLAMing when:
