Results 1 to 12 of 12
Thread: Calcium Chloride Question
    Aug 2013
    San Tan Valley, AZ
    17
    Hello,
    Today I added about 14lbs of CH Increaser to my pool as it was originally filled with soft water testing at around 80ppm. My goal was to raise it to around 200-250. Now my concern is that since I have added the increaser I can't seem to manage my FC level. It has been dropping a few ppm about every hour it seems. Is this normal?? I had to add about 200 or so ounces of chlorine today alone in order to keep it up. I'm concerned that when I get up tomorrow morning the FC level will be at zero once again.
    Any help here would be great. Thanks.
    ____________________________________________________
    12,000 gal | IG Gunite w/ Pebble Tec | 3-5-4' depth w/ Waterfall
    Pentair IntelliFlo VS Pump, Cartridge Filter
    Manually Chlorinated
    Testing w/ ColorQ Pro 7 and K-2006
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Calcium Chloride Question
    For us to help, we need a full set of test results. Post FC, CC, ph, TA, CH, cya using your K-2006 test kit.
    Quote Originally Posted by kendjelic
    No
    Aug 2013
    San Tan Valley, AZ
    17
    I will post results tomorrow morning. Everything was perfect since the increaser addition. Also is there a reason I shouldn't test with the ColorQ Pro? My results are almost exact to the K-2006 results. Only numbers off by only a couple ppm are the CH and CYA test, all other tests are exact.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Just for fun, would you be willing to post results from both?
    30,400
    Back to your original question, Calcium has no effect on your pool's ability to hold chlorine.
    Aug 2013
    San Tan Valley, AZ
    17
    Well it looks like perhaps I may have not waited long enough to take a water sample as I took it from the inline spigot and not from the pool itself as I normally do.
    Either way, it looks like the chlorine is holding fine now.
    Here are the test results from both kits as requested from 8:30am this morning. Looks like the ColorQ is reading a bit lower than most of the K-2006 results except for CH.
    ColorQ Pro:
    FC - 8.5
    pH - 7.7
    TA - 89
    CH - 236
    CYA - 72
    CC - 0
    K-2006:
    FC - 9.5
    pH - 7.8-7.9
    TA - 100
    CH - 210
    CYA - 80
    CC - 0
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    How is your water looking? Did you happen to take a FC measurement last night after your last addition from the bulk pool water?
    Aug 2013
    San Tan Valley, AZ
    17
    Yeah last night at about 1am the FC came in at 10. Water looks beautiful. The attached picture was just taken looking in at the drain.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Assuming the 10 ppm FC came from K-2006 then you it appears you have passed the OCLT and are good to go.
    Your cya is very high for a non-swg pool, so do not let your FC get below 6 ppm. If you continue to see high daily FC usage I would repeat the OCLT but this time get up near your SLAM level of 31 ppm when doing the test.
    Aug 2013
    San Tan Valley, AZ
    17
    Regarding the CYA, I drained about 12-16 inches from the pool yesterday and refilled with our hard tap water as the pool was originally filled using our water softener which was a mistake hence my adding 14lbs of hardner. My test were reading my CYA at about 100-110 consistently so was hoping to drop it some which it did although not much.
    Living in AZ, our pool is in direct sunlight daily and today the high is 103. Would lowering my CYA to about 40-50 cause a concern as I would assume that sun would eat all of my chlorine in a heartbeat.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Yes, with an algae free pool, you would use more chlorine at 40-50 ppm cya compared to 80 ppm.. 80 ppm can and does work, but you must be vigilant. If your FC drops and you get algae, it will take much more chlorine to remove it.
    Aug 2013
    San Tan Valley, AZ
    17
    Makes sense. I check it every night so as for now I'm on top of it. Do my other figures look ok?
