Thread: New to TFP - High PH
    Jul 2013
    Rancho Cucamonga, CA
    15
    I'm a convert. I've switched to liquid chlorine from pucks and slammed my pool effectively once. The water has never looked as beautiful. However, my PH is pretty high right now. Here are my readings from today:
    CL - 6.5 (added some this morning)
    PH - 8.2
    TA - 90
    CH - 340
    CYA - 38
    I should be lowering PH right? Should I add stabilizer to lower PH and increase CYA?
    I'm a little confused. Thanks for your help.
    ~20,000 IG Roman Shaped Plaster Pool with Spa
    Cartridge Filter (Hayward C4025)
    Pentair Supervlow VS 342001
    TF-100 Test Kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,658
    Re: New to TFP - High PH
    You can lower your Ph quickly with muriatic acid. Depending where you are, your cya could be fine. Judge it by your FC daily loss.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Adding stabilzer (cya) is not a good way to adjust ph since the stabilizer does not disolve quickly and doesn't move ph much in the amounts you could use.
    Use Muriatic Acid to adjust ph. If your ph is reading 8.2 it can actually be much higher. I would use poolcalculator.com to calculate how much you need to go from 8.2 to 7.4, then add it in front of a pool return and test the water again in 1 hour. Redose and retest as needed to get down in the 7.5-7.8 range.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Just adjust pH using Muriatic Acid. You'll probably need to start doing that - the pucks were taking care of it for you as they're very acidic.
    I'd hold off on raising CYA. That way you have a little breathing room if you want to leave town for a few days. You can load a floater with pucks to keep that sparkly pool going in your absence without worrying about overdoing the CYA that way.
    Jul 2013
    15
    Thanks guys, I'll give it a shot in the morning.
    TF-100 Test Kit
