Results 1 to 10 of 10
Thread: New Pool - Starting with BBB
    Our pool was just installed and filled. Here are my measurements with the TF100
    FC: 1
    pH: 8.2
    TA: 40
    CH: 110
    CYA: 0 (poured it to the top and could still see the dot - water was clear)
    According to the Pool Calculator I should add 71oz of the 8.25% strength bleach I have and 84oz of the powder stabilizer. Does all this sound on track? Any other recommendations?
    18'x33'x52" (15,700gal) AGP. Buried 18"
    1.5hp Pump w/ 150# Sand Filter
    TF100 Test Kit
    BBB Method
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: New Pool - Starting with BBB
    pH to 7.8 or lower.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    After the pump runs for 30 minutes after adjusting your pH, add some chlorine and then hang enough CYA (Conditioner) in an old sock in front of the return fitting (way from wall) to get you to 30-40PPM. It may take a couple days to dissolve the CYA.
    -- Guy --
    Thanks for the replies!
    I've got the stabilizer in a sock in front of the skimmer now and about 1/2 the bleach added. I thought I read where you need to break up adding bleach into a couple doses.
    I'll read on Pool School about lowering the pH. I had the bleach and stabilizer on hand but that was it.
    TF100 Test Kit
    BBB Method
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    NOPE... adding all the bleach in front of the return in one pour is fine. I think a practical limit of one jug at a time; then do the next one if you need to.
    I like to pour it in a stream less than a pencil in diameter so it mixes well with the water.
    -- Guy --
    Ah-ha! Good to know. Sometimes it might be a hassle to split it up.
    TF100 Test Kit
    BBB Method
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    We recommend breaking up muriatic acid into 32 ounce doses at a time generally.
    After I add the MA how long should we wait before anyone enters the pool?
    TF100 Test Kit
    BBB Method
    Jun 2012
    Howell, NJ
    977
    30 minutes to an hour should be fine.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Thank you!
    TF100 Test Kit
    BBB Method
