Results 1 to 12 of 12
Thread: PH climbing daily by .3
    SunMan's Avatar
    Jun 2013
    Phoenix, AZ
    20
    Still fairly new to pool school, but my water is brilliant and I no longer am dealing with the idiots at the pool store My concern is that my PH is climbing daily by .3ppm, so every 3 days I'm adding about a quart of 31% muriatic acid. I daily replenish my chlorine with about 20-28 oz of liquid @12.5%. I would like to find a way to stabilize the PH. Any thoughts?
    BTW, over the past 30 days my CA has gone from 50-60.
    Test results:
    FC 6
    PH 7.8
    TA 80
    CH 300
    CYA 60
    CC 0
    Salt 1825 for feel
    Shasta 10,500 gallon play pool/spa, pebble tech finish (10/12), in floor cleaning, 2' free-fall, deck jets, Hayward 2hp SP3400VSP pump, Jandy 8 cartridge filter, LX heater and AquaLink Sunny Phoenix, AZ
    38,252
    Re: PH climbing daily by .3
    Do you have any aeration like a waterfall, spill-over, etc? That can drive the pH up.
    The way to slow the rise is to lower the TA. This can eiterh be done passively by keeping the pH in range and the TA will slowly drop, or more aggressively following the article in Pool School.
    SunMan's Avatar
    Jun 2013
    Phoenix, AZ
    20
    I have a 2' high waterfall which is seldom used and there is a spillover from the spa with only a 1"drop. So now I am confused because the pool calculator tells me to aerate to lower my TA (which I thought was fine to start with since it is in the suggested 70-90+ range).
    Jun 2012
    Howell, NJ
    977
    Lowering TA is a process. You add Muriatic Acid to lower the pH and TA, and then aerate to raise the pH back up. You repeat the process until your TA is at the desired level. Aerating, by itself, doesn't lower TA at all.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Do you run your deck jets a lot? They will raise ph very quickly.
    SunMan's Avatar
    Jun 2013
    Phoenix, AZ
    20
    No to the deck jets. Seldom even use the pool except on weekends. Did get the TA down from 140 at refill 30 days ago. I'll just keep working on lowering the TA. Any ideas where the raise in CYA came from? Muriatic acid perhaps?
    CYA only goes up when you add products which contain CYA, typically trichlor tablets, or granular dichlor. Muriatic acid does not contain any CYA.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    When you add cya by using granular stabilizer, it can take up to a week to show up in tests after it disappears into the water.
    SunMan's Avatar
    Jun 2013
    Phoenix, AZ
    20
    The only thing I have put in my pool since I started reading this forum is liquid chlorine, salt and muriatic acid. So the CYA remains a mystery.
    Feb 2008
    Denton, TX
    5,061
    CYA readings increasing by 10 without the addition of any CYA during that time is testing variance. That's all it is.
    Your plaster is less than a year old, right? It is still curing and therefore, your acid demand will continue to be high. You can lower your TA somewhat, but you will still need to add acid fairly frequently and in good amounts because you have new plaster.
    30,403
    The margin of error in that test is easily 10 ppm. As said before, CYA only increases in your pool if you add it.
    SunMan's Avatar
    Jun 2013
    Phoenix, AZ
    20
    Thanks Weatherby for the insight on the plaster cure. I also can accept the test variance for the cya being user error. I think I'll just hold my TA at the low end of the recommendation and wait out the PH rise with MA Thanks again to all who responded!
