Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: New Pool owner - bought a pool and house that are 1 yr old
    Jul 2013
    Chandler, AZ
    43
    Hi,
    Bought a 1 yr old house with a pool 3 months back in Gilbert, AZ. Direct sun light all day.
    Got the pool serviced by someone paying 85 per month.
    After coming across this site got the confidence to maintain on my own. So, discontinued the pool service. It has been week since the pool guys last visit.
    Bought Taylor K-2006 kit. Tested and got these results..
    FC - 4
    PH - 7.7
    TA - 110
    CH - 450
    CYA - 120
    Added 62 oz Clorox bleach... now FC is at 7.5
    water is very clear. Should I be worried because of high TA, CH and CYA values? Do I need to replace water. Not sure how to drain it.
    Also, pressure on the filter is 2psi.
    Planning to jump in the pool with kids this afternoon. Is it safe?
    Appreciate any suggestions.
    Thanks
    12x40 In ground, 16K Gallons, Pentair VS pump, 420 catridge filter, 140HC Heatpump, Stonescapes pebtec surface, Chandler, Arizona
    38,470
    Re: New Pool owner - bought a pool and house that are 1 yr o
    Welcome to TFP!!!
    The CH and TA are not a problem. The CYA is definitely a problem that will require water replacement. Since pool companies only come weekly, they often run the CYA up much higher than we recommend.
    I would suggest doing the CYA again with a 50/50 mix of pool and tap water, then add the reagent, and double to reading to find out how high the CYA really is ... and tell you how much water you should replace ... or at least that will tell you how high you need to keep the FC.
    For examply, using 120ppm in poolcalculator.com, the minimum FC you should be maintaining is 9ppm to be safe. Of course there is a chance the CYA is really even higher.
    Jul 2013
    Chandler, AZ
    43
    Thanks jblizzle! That's a great idea to mix with 50% tap water to get the accurate measure of cya. Will do that.
    38,470
    Realize too that you can pour the mixture back and forth a few times to see if you consistantly get the same reading. Also, lighting is very important for that test. It should be done outside with your back to the sun and the tube at waist level.
    Jul 2013
    Chandler, AZ
    43
    Thanks! I tested 50/50 pool water and tap water mixture for cya. I got 70. So, assuming cya is 140. Do you suggest replacing water or bumping FC up? Tested FC and PH today. Got 6.5 and 7.7 Respectively.
    30,431
    We suggest anything with CYA of 100 or more to be close to unmanageable. The best approach by far would be to lower your CYA
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    In your photo I think I see an open pipe with a 2-way valve next to it...if you open that while the pump is running, you will drain the pool. Probably rather quickly. If you have a backwash hose laying around, you could just attach it there and dump the water in your sewer cleanout, or into the street drains if that's allowed where you live.
    Jul 2013
    Chandler, AZ
    43
    Thanks for all the suggestions. I just wanted to update. After googling a lot about these, I found it is not easy to drain my pool into the street drains or sewer cleanouts. Looks like I need HOA and city's permission. Also, I don't have backwash hose. So, I am draining little bit of water everyday into my back yard and letting it dry all day. with Arizona heat, it is not taking that long for it to dry out. I think I would replace 40% within a week. I will test my cya again then.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Are you able to drain inches at a time? You should be able to calculate how much you need to drain and then when you need to stop.
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Jul 2013
    Chandler, AZ
    43
    I think I am able to drain approx. 3 inches at a time. I had cya of 140 before I started this. To bring it down to cya 90, Pool Calculator suggests to drain 36%. Is that what you mean?
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    7 days draining 7.5 inches followed by refill to original water level will lower your cya from 140 to ~ 50 ppm cya (assuming an average depth of 4.5 feet in the pool). If you can only do 3 inches per day, it will take ~ 18 days (and a lot more water than a single partial drain/refill).
    Jul 2013
    Chandler, AZ
    43
    I didn't realize I am also draining the fresh water. I'll look into options to single drain. I'll buy a backwash hose and findout about the HOA and city.
    What should be my target cya? 90 or 50? can I follow these steps? turn off the inlet valve. Keep pump running while draining out water. drain probably 2 ft or so (depending on my target cya and what pool calculator suggests to achieve that target cya). Then, turn on the inlet valve. when I am done refilling, test the water and proceed from there?
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Thanks Linen didn't feel like calculating that lol! Sounds like midnight drain might be in order... Or drain via bathtub....
    18'x43' Sport Pool
    38,470
    You are not backwashing DE into the sewers, so I am surprised that you can not just pump the water into the street ... although I know that all kinds of places have various regulations, whether they make sense or not.
    Or just get a hose and spray it around your yard ... or do a VERY VERY thorough job rinsing off your cars in the driveway
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Since your in Arizona, you might be able to get away with/benefit from slightly higher cya levels...maybe shoot for 70 and see how that works?
    Jul 2013
    Chandler, AZ
    43
    Appreciate all the suggestions. I like the idea of thorough rinsing off cars. May be I can wash my patio, garage too and spray the rest around the yard.
    This may be a dumb question... Is there a way to connect a regular hose? may take longer... but, would be much easier to handle during all those washes. May be backwash hose is easier to handle? I never used one before.
    38,470
    Not with the way it is currently plumbed. You would have to add some fittings/adapters to connect a hose bib and then a hose. Realize that you do not have to open the 2-way valve all the way and can control the amount of water coming out that way.
    Jul 2013
    Chandler, AZ
    43
    Here is a closeup picture... there is a valve towards the bottom left labeled with 'Drain' on one side and 'Skimmer' on the other side. I am assuming I have to shut it off during the draining so that it won't try to get water through Skimmer, correct? Otherwise, it may suck air when the water level is below skimmer?
    Any idea on which way I should turn that valve to shut it off. May be I can try different positions and run the pump on full speed (that's the only time I can visually notice water being sucked through skimmer) to figure it out. But, I am not sure if I can run pump on full speed while the skimmer is closed.
    Also, any idea on what does that DRAIN label/option for? is there an option to drain it through the plumbing that is already connected to somewhere? Or am I too greedy to expect something like that
    38,470
    Kind of a weird plumbing setup, but yeah, you need to close off the skimmer side. The tab opposite the handle says CLOSED ... that tab should be on the skimmer side. This is the suction side. The DRAIN is the floor drain.
  20. Back To Top    #20
    Jul 2013
    Chandler, AZ
    43
    Just an update... got the backwash hose and drained 2 ft of water... took about 8 hrs at the least speed. Sprayed it around the back yard. Now, refilling it.
