Thread: Draining Pool
    Jul 2013
    Dallas, Texas
    1
    Draining Pool
    Ok.. I am a new pool owner and I am so thankful I stumbled upon this site! I have been battling algae and realized that my CYA is too high-100 is all I got from my strip and also from LP store. I am getting the suggested test kit so I can SLAM my pool..but first I want to drain some water to get the CYA down. If I understand what I have been reading..I don't have to get a sub pump if I can drain from the bottom?
    14K gal, IG-plaster, 1.5HP WhisperFlo pump, 48sqft-DE480 filter, GPM-120
    22,550
    Re: Draining Pool
    If you can isolate the main drain or have a vacuum hose that you cna use to drain water from the bottom you can use your main pump. Since you have a DE filter, if you have a multiport valve, you can just pump it to waste.
