Thread: Best Pump Size for 18' AGP
    MermaidMama's Avatar
    Aug 2013
    Pennsylvania
    158
    What size pump would recomend as the minimum, and what would be perfect size?
    Thanks so much!
    MermaidMama
    18' Round x 52" Doughboy AGP ~ TF-100 Test Kit
    Powerline XP Pump 1.5 HP ~ AquaView 20" Sand Filter ~
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Best Pump Size for 18' AGP
    Welcome to tfp, RALFINA
    I would recommend a small 2-speed pump. Pentair has a 3/4 hp 2-speed dynamo that might be a good fit. Running on low speed most the time will save electricity.
    What filter do you have?
    Aug 2013
    Pennsylvania
    158
    Well, I have a "package deal" that includes a Doughboy AquaView Filter and Powerline XP Pump. He never specified the sizes, so I want to ask him and just wanted to be a little knowledged when I speak with him. I just want to see what was recommended for a 18 foot and make sure he includes that or I upgrade.
    Thanks for the help. I'm new to all this, so I'm sure I'll be back for more info.
    MermaidMama
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I am assuming this is a 18' round pool with 54" walls? If yes then the volume is ~7600 gallons.
    Make sure that aquaview sand filter is at least the 17 inch one, though generally bigger is better on the filter (I wouldn't hesitate to go up to the 20" if the price was not bad).
    It looks like the powerline can be ordered as a 2-speed, I would get the 2-speed if possible though it looks like the smallest 2-speed they offer is a 1 hp? That still should save you electricity in the long run on low I would think. If you do go with a single speed, I would go no larger than the 3/4 hp. By the way, dougboy does a horrible job on their website specing their pumps. I had to look at the owners manual just to see an 1 hp 2-speed option.
