Thread: cya test
    cya test
    I have a question about testing your cya, do you fill the vial until the dot can't be seen at all, or until it just starts to fade out? Seems the more I look at it, sometimes I think I can see it and sometimes not...
    16500 gallon plaster, BBB
    22,550
    Re: cya test
    Until it's like it was never there.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: cya test
    +1
    Very good description
    Essential Links:
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: cya test
    See this link. Don't go crazy looking for it. If you are saying to yourself "I think there might be a dot, but I'm not sure", then it's probably not there. You can always add more to the tube to see if it changes, then pour some back in the bottle and do it again until you get a reasonable sense for it. It's more a matter of practice. What is important is to stand outside with your back to the sun holding the tube in front of you looking straight down into it. Hold the tube from the top so that you aren't blocking the strong indirect light into the sides of the tube.
