Results 1 to 7 of 7
Thread: Staining on pool light and skimmer entrance
    Hello Folks,
    We haven't swam in the pool for about a week and a half because the weather hasn't co-operated. But I took the cover off last night to clean the pool for my daughters birthday party this weekend and found some staining on my lights. One light has just a little, while the other one has allot. These lights go into the side wall of the pool.
    Pool Specs - 16,000 gal. fiberglass, SWG with Cartridge Filters
    The water is clear as you can see from the images below.
    Here are the specs:
    Pool Type - Fiberglass
    Pool Size - 16,000 gal.
    Chlorine - SWG
    Filter Style - Cartridge
    FC - 4.64
    TC - 5.14
    CC - 0.5
    pH - 7.8
    Hardness - 192
    Alkalinity - 97
    CYA - 65
    Copper - 0.2
    Iron - 0.1
    Borate - 6
    LIGHT #1
    This light is furthest away from the returns and as you can see has just a little bit of staining around the outer edge of the white part of the light.
    Light #2
    This light is closest to the returns and as you can see has alot of staining on the front and the backside which goes into the wall of the pool.
    The pool store gave me some metallic stain remover, but he said he wasn't sure if it would work or not. I thought I would check here to find out what you folks think. If the stain remover won't work then I will just take it back to the store.
    SKIMMER
    This isn't really staining but more or less fading I think, but the top edge of my skimmer entrance is fading. Our pool gets allot of sun (new sub-division) so I am not sure what I can do.
    What are my options to clean this up? could I get a new cover to put over it? or is this just something I have to live with.
    Leisure Pools - Rivera (16,000 gal.)
    Pentair System: IntelliChlor IC20, Clean & Clear Plus Filter, MasterTemp 250 Gas Heater, SuperFlow Pump
    22,553
    Re: Staining on pool light and skimmer entrance
    Have you tried a vitamin C tablet on the staining? That's where I would start, if you haven't.
    Went and got some vitamin C and will try that when I get home from work.
    Any thoughts on the skimmer?
    22,553
    Try Magic Erasers and see if that cleans it up. You might try the Vitamin C too.
    Tried rubbing the vitamin C. Don't know how it works but at the rate I was going it would have taken 3 bottles of the stuff to make a slight difference.
    So I have to assume if vC would have worked then it wouldn't have been this hard.
    What now?
    22,553
    If it worked at all it means that it metal stains and an AA treatment will take them off if they bother you that badly.
    Jul 2011
    Arizona & California
    805
    The yellow-orange-tan color on lights is an iron deposit. Use 1 part muriatic acid to 4 parts water in bottle and squirt on. It is more potent than the other treatments and should remove it easily. Rinse with tap water afterwards.
    Should work on skimmer too.
